586,103 active members*
3,855 visitors online*
Thread: dsPic-Servo
Page 4 of 9 23456
Results 61 to 80 of 172
  1. #61
    May 2007
    106
    Hi folks,
    YTT is on good way. I tried the parser with a loopback interface, works correctly
    Now, got to make dsPIC's side code.
    About YTT's code, well it's rather useless posting it here with no explanation. There are many things to do before you can compile it. I'll try to explain important steps in a document. Be patient.
    PS for Garry: Your routing skills seems a lot better now
    What current rating are you aiming with this board?
  2. #62
    Mar 2005
    523
    Hello MaX-MoD
    as for trace current.
    the smallest power trace on my pcb is 155 mils.
    the pcb guy says.
    -at 1 oz copper this trace will handle 6.5 amps (unTinned)
    with tinning he says about 8 amps continuous.
    - he says 2 oz tinned copper will be about 10 amps.
    - 4 oz copper 15 amps would be pushing it, but probably ok.
    the pcb cost is almost 50% more when one goes to heavier copper
    due to echant machine time adjustments and copper prices. ( he says)
    reguards garry
  3. #63
    May 2007
    106
    Thanks for the infos Garry. I have read similar data on PCB manufacturers' websites, so I guess it's okay
    Besides, I am getting a servo and an amp this week, so I'll test the 10V version.
    I am also planning on getting some pro's PCBs in a few weeks, so is anybody interested ?
    I'm not planning on taking much boards (15-20), but if one need on or more, please let me know!
    PCBs' price will vary from ~12$ for small qty to 5$ or less if lots of ppl are interested
    PS: latest source and scematics
    Regards,
    Max
  4. #64
    Jul 2008
    hello,
    what software to view the files for this project
  5. #65
    Sep 2007
    22
    hello,
    i am interested in getting a pcb to evaluate.
    let me know.
    roger
  6. #66
    May 2007
    106
    Hello dski, hello Roger,
    The software used to view the PCB is KICAD.
    Roger,
    In addition to the 12 PCBs I am getting for other ppl I'll take at least 8 more, so I'll keep one for you.
    Oh, a friend just lent me a servo and its amp. The only problem is the configuration software... under DOS on a floppy disk (nuts)
    I should be able to get a floppy disk reader next week, and therefor being able to configure the amp and to TEST THE BOARD!
    I'll post a vid ASAP
    Regards,
    Max
  7. #67
    Feb 2005
    122
    Max, I want some boards too !
  8. #68
    May 2007
    106
    Hello dan
    No problem, bare PCB or mounted&tested? how much boards do you want?
    maybe we should continue in PM
    Regards,
    Max
  9. #69
    Sep 2007
    22
    what is happening with everyone
    hello all . . .
    what is that status with everyone's projects?
    i have had to work more lately than i desired .. so my projects are going slow.
    roger
  10. #70
    Mar 2005
    523
    hello
    i have my pic servo controller hard wired on a perf board and will be ordering the parts tomorrow.
    when the circuits are proven i will get some pc boards made and offer them assembled and in kit form.
    if i use 2 oz, copper the traces should be able to hold about 10 amps,
    4 oz copper about 15 amps.
    with software and a jumper change the controller will be able to handle 3 phase motors and be able to be used as a dc to 1 phase or 3 phase ac converter as well.
    attached it the proposed pc board.
    i expect to have this project complete in about 4 weeks , hopefully sooner.
    cheers garry
  11. #71
    Feb 2007
    4553
    Question
    Garry,
    Any idea what the cost will be?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  12. #72
    Mar 2005
    523
    Hello
    I have ordered the parts for this servo controller.
    For now i will call it "mtmc" multi type motor controller.
    I have the circuits layed out on a solder perf board.
    When all is tested good I will offer this project as follows.
    1. Complete units, assembled and tested.
    2. Complete Kits, all components not soldered on the pcb
    3. Complete Kits, with only the surface mount parts soldered.
    4. Probably other configurations like heat sinks, mounting plate, etc.
    attached is an estimated parts cost
    schematic, pcb layout
    a few other associated pages
    Nothing is carved in stone here and I will keep you posted.
    reguards Garry
    Attached Files Attached Files
  13. #73
    Dec 2008
    51
    Dir smarbaga,mtmc can controller bruhless servo?? i don't see current sense for u and v phase?
  14. #74
    Mar 2005
    523
    mtmc
    to nhatson
    thank you for pointing that out.
    i will see if i can add another current monitor chip.
    that's not going to be to easy, but i might get lucky
    and find another sq. inch
    i have the current of the motor power supply monitored,
    not the individual phases, i hope this will suffice.
    i am always open for sugestions, as no boards have been ordered yet.
    thanks again.
  15. #75
    Dec 2008
    51
    i think use lowside current sense is easy and cheap.
    b/r
  16. #76
    Feb 2007
    4553
    Garry,
    Awesome to see you guys work, I cant believe how fast you put that together.
    Where are you located?
    Jeff...
  17. #77
    Mar 2005
    523
    jalessi
    thanks
    6 months ago i was your neighbour in logansport indiana
    i have now moved to ontario canada.
  18. #78
    May 2007
    106
    Hello,
    The 10V version successfully controls a 500W (3/4hp) AC servo! :cheers:
    This little baby can go from 0 to 2000rpm in less than 0.3seconds, impressive!
    Now, the boring part : RFQ at PCB shops and order @ Mouser!
    [ame="http://youtube.com/watch?v=x_aorBS_nAY"]http://youtube.com/watch?v=x_aorBS_nAY[/ame]
    I will start a new tread soon...
    PS: The new tread
  19. #79
    Dec 2005
    59
    hi guys!
    awesome work, really. I have a question about C30 and PIC brick programming. I have only played with AVRs and don't know how to manage with program compiling and programming the PIC. Is it possible to attach compiled HEX file, just ready to put on PIC with any kind of programmer? I'm trying to make my little wooden desk machine alive with small DC motors from old printer. But manofactured PID-like controllers are too expensive for me and i'm looking for "self-made" version (i mean made with my hands only with mental help from people like you are;P). Have anyone some movie with this controller in action?
  20. #80
    Jan 2009
    334
    dspic30f4012
    I noticed that there are two versions of dsPIC30F4012 device. A 20 MIPS version and a 30 MIPS version. Does it matter which one is used for this project? I am currently working on a slightly different design using 2 OPA549T amps.
    By the way, here are pictures of the modified universal magnetics servo motors. I have drilled and taped them for 500 CPR encoders.
    Attached Thumbnails Attached Thumbnails before modification Univ mag servo motors 6801_3.JPG   servo motors new encoders.jpg   O Scope 3.jpg
Page 4 of 9 23456
  1. Replies: 0
    Last Post: 02-07-2014, 01:29 AM
  2. help me with dspic 30f4012 project
    By caligroup in forum Community Club House
    Last Post: 08-16-2010, 03:59 PM
  3. first steps with dsPIC + IRAMS AC servodrive
    By andy55 in forum Servo Motors / Drives
    Last Post: 07-10-2007, 07:55 AM
