586,089 active members*
3,820 visitors online*
Thread: G71 cycle
    Sep 2005
    274
    G71 cycle
    When programing a G71 rough turning cycle, I was taught to always start and end the X at the same diameter, now I see programs that start and end at different diameters and they work, I thought the tool would come out at a angle of the 2 diameters when done, now I see it will come out to Z start point straight and then move to the start X diameter, is this something new on newer controls? (this is a 0i TD and a 21i TB) or was I wrong all these years? Thanks
    Sep 2005
    274
    Re: G71 cycle
    Nothing?
    Nov 2009
    19
    Re: G71 cycle
    I have a 18i from 2006 and the point I go to before calling the g71 is the startpoint of the cycle. After g71 I rappid to start contoured and go g1 to the end of the contour.
    Sendt fra min ANE-LX1 med Tapatalk
    Sep 2005
    274
    Re: G71 cycle
    Thanks for the reply, yes I see what your doing, like I said I always start and end at the same X diameter, it seems like the older controls if you had 2 different X start and end points, when it was done it would come out at a angle and that could be trouble, the newer controls wait to go back to the X start diameter after it comes out to the start Z position and I like that better. just want to know if I'm rite thanks
  1. Bodor Laser i3 - PLC Control (Cycle Start and Cycle Complete)
    By jcampa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-19-2019, 04:09 AM
  2. Replies: 0
    Last Post: 02-02-2017, 04:08 AM
  3. CYCLE 83: pecking cycle with deepened starting point
    By Bastida in forum SIEMENS -> GENERAL
    Last Post: 12-18-2011, 04:25 PM
  4. Heidenhain iTNC 530: Using Cycle 19 and Cycle 8
    By Dan B in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-27-2011, 05:32 PM
