586,664 active members*
5,219 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Planet mk3 input/output noise, Need help!
Results 1 to 7 of 7
    Jun 2015
    29
    Hi everyone, I have a problem with my mk3 controller board. All of it's input/output had noised after getting wet during operation.
    This link below show exactly what going on with it. Can you give me some advise?
    https://www.youtube.com/watch?v=_mq2YYywnPI
    Mar 2017
    1319
    Re: Planet mk3 input/output noise, Need help!
    Which part of controller got wet?
    Aug 2011
    999
    Was it just water or something else? If the liquid contained any salts you may be out of luck. I believe the boards are conformally coated but even that is not always waterproof.
    Did you try to bake the board at, lets say, 70 degrees C for a while? There may be some liquid hiding under the chips that takes longer to dry out.
    May 2008
    266
    It might need some compressed air around it to shift any remaining moisture.
    Jun 2015
    29
    Quote Originally Posted by PlanetCNC View Post
    Water overflow on the upper surface of the board. LIMIT, JOB and IN/OUTPUT ports were no longer seems to work correctly. What do you think about replacing the HC224 IC ? Thank you a lot.
    Jun 2015
    29
    Quote Originally Posted by JerryBurks View Post
    Thanks Jerry, It's just only water and I haven't tried your way yet. I will give it a try.
    Jun 2015
    29
    Quote Originally Posted by blowlamp View Post
    Thanks for your advice. I tried to dry it with compressed air even the dryer but nothing changed (
  1. Planet CNC Mk3/4 Output count expansion
    By lh-cnc in forum PlanetCNC
    Last Post: 01-03-2019, 11:25 AM
  2. Replies: 1
    Last Post: 10-19-2017, 12:48 PM
  3. Noise in input pins
    By Shessek in forum DIY CNC Router Table Machines
    Last Post: 01-12-2016, 11:27 AM
  4. Can I swap an output pin to an input?
    By GTFreeFlyer in forum Mach Mill
    Last Post: 12-22-2013, 05:26 AM
  5. Stepper noise/vibration video- looking for input
    By Jimdandy in forum Stepper Motors / Drives
    Last Post: 07-02-2013, 07:50 PM
