586,058 active members*
4,525 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa SGDB-02VN with Mach3
    Hello
    I am trying to get an old Biesse rover 23 running with mach3 and Smoothstepper Ethernet 51 I/O Motion controller. Looking in the manual, I have found a "connection and wiring" for Mitsubishi and I thought I could use this but with smoothstepper instead using pin an dir..
    I am stuck with the pinout from the SGDB-CANV, I can not find any manual, after days of looking, wich pins are what in the 13 pins jacket labaled 1CN.
    Any ideas?
    Attached Thumbnails Attached Thumbnails ScreenHunter_1005 Sep. 03 23.07.jpg   ScreenHunter_1004 Sep. 03 23.06.jpg
    Re: Yaskawa SGDB-02VN with Mach3
    SGDB-xxxN are early Mechatrolink-I drives. the bus gets connected to the blue 8-pin honda connector at the top left. 1CN circled in red is for limit switches and the like.
    the manual is available on the web, google for SIE-S800-26.4B. i doubt about mach3/SS...
  1. yaskawa SGDB-10VD Drive
    By tracar in forum Servo Motors / Drives
    Last Post: 11-03-2019, 05:07 AM
  2. YASKAWA SERVOPACK SGDB-10VD
    By bujar.gashi in forum Servo Motors / Drives
    Last Post: 07-02-2018, 02:51 PM
  3. Swap yaskawa sgdb-15adg for a sgdb-10adg
    By gzero in forum Servo Motors / Drives
    Last Post: 08-24-2016, 04:55 AM
  4. Need replacement for yaskawa sgdb-10adg
    Last Post: 02-23-2015, 01:54 PM
  5. Cable for programming Yaskawa SGDB Parameters
    By grc in forum Servo Motors / Drives
    Last Post: 08-30-2010, 03:00 AM
