586,061 active members*
4,413 visitors online*
    Sep 2008
    25
    Basic hose question
    I have an automotive application. OEM "rubber" hose on this engine often fail. After several years the manufacturer replaced it with solid line. Earlier year owners often swap out the rubber for the later year solid. This is too involved for me right now, so i was just going to get the best high temp high pressure "rubber" hose and good clamps and inspect it often. Then i thought maybe some Wire braided hydraulic hose?
    I know that then my end clamps would really be my weakest component, so maybe im going way over kill here.
    In this application the hose is located between engine components with not much air movement and is also subject to pvc gases.
    This is for rear VVT-i hose on toyota 2gr-fe engines which they use in many car models. Im dealing with a 2007 avalon which from what ive read is the most involved when replacing the entire line with solid. There are additional reasons that id rather not replace entire line now.
    Thoughts?
    Tks, pa
    Sep 2008
    25
    Re: Basic hose question
    who makes the best strongest rubber oil line automotive hose? Best clamps?
    Dec 2013
    5717
    I think this is what you need for that application. https://www.amazon.com/Walker-36344-.../dp/B001BFLJI0
    Should be able to find this at your local auto parts store.
    Ideal makes good stainless hose clamps. https://www.amazon.com/s?keywords=Wo...s_id=979130011
    or available at any auto parts store.
    Jim Dawson
    Sandy, Oregon, USA
  1. The most basic question
    By cncuser1 in forum Servo Motors / Drives
    Last Post: 09-26-2018, 09:34 PM
  2. basic question (hopefully!)
    By jay_dizzle in forum Okuma
    Last Post: 09-13-2018, 11:56 AM
  3. What is the different between 2 hose and 3 hose oxy cutting torch
    By asuratman in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 05-02-2015, 12:50 PM
  4. Flex hose question
    By SScnc in forum Benchtop Machines
    Last Post: 08-06-2008, 03:59 PM
  5. a very basic fan question.
    By cyclestart in forum CNC Machine Related Electronics
    Last Post: 07-07-2008, 12:43 AM
