Hi
I am doing a lot of inside cutting of circles in Dibond, and because the bit slows down then stops at 360 degree when finishing the circle, there is a lot of material left hanging at the end as higher rpm with close to zero feed rate mets the plastic.
Is there a way to go longer than 360 so I can clean this?
Marius
