I am having a problem I cannot seem to fix.
I have a heavy duty CNC Router I built (steel)
Running al AC Drives (Yaskawa and Automation Direct)
and Mach 3
The machine is dead on for every thing else so this is not a back lash issue.
When cutting out circles I seem to run into an issue with a diagnal elongation
basically a ovaling at 2:30 and 7:30 (or 40degrees and 210degrees) on every circle.
It seems worse or more noticable with smaller circles say 3/8" diameter
I am cutting G10 Fiberglass Sheets
I talked to Art from Artofcnc (Mach 3) and he thought it was a servo gain issue, or something like that.
Has anyone else had this problem or know how to fix it ?
Curtis
