586,308 active members*
3,496 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Most stable versions of mastercam?
Results 1 to 10 of 10
    May 2013
    149
    Hello, everytime artsoft upgrades the gui, the stability of the software takes a nosedive.
    Can I please have your opinions on the most stable versions?
    I have used V8,V9 and X5, all are very stable and hoping upgrade to a simlilar level of performance.
    Apr 2019
    58
    Re: Most stable versions of mastercam?
    I use 2018 with updated latest pack.and it is stable.
    [email protected]
    +37060022992
    Apr 2003
    3578
    2021 is stable
    Cadcam
    1228
    Given the price of the software I would expect quite an outcry if it wasn't stable and an almost instant fix for any problems that became apparent.I haven't seen any news of such things and draw my own conclusions.
    Sep 2009
    78
    Quote Originally Posted by routalot View Post
    There's plenty of issues out there that people talk about. It's typically a fraction of the users complaining about it and the other users that have issues suck it up because they don't feel like being critical of what they use.
    let me say I think MC is a pretty decent mid-tier software and it does a lot of things well. Our MC programmers are mostly using 2020 on Dell Precision workstations with Quadro cards and see occasional crashes. We manufacture medium size molds and personally I feel MC reaches it's capabilities here then the crashes start happening and it's been like that every version. Docs still broken so we're using a 3rd part docs solution. IMO if you do prismatic part machining MC will eat it up and perform well for you, small to big, 3-5 axis. However, every mold shop I know of has stability issues and had them forever. Getting into large 3D projects with stock models, lots of roughing, lots of rest roughing, semi finishing and finishing with a plethora of cutters is where we're seeing crashing issues and cnc software isn't doing much about it. They seem more interested in new features than refining their which really makes life hard for a lot of shops.
    NX 10.0.3
    May 2006
    132
    i am making die cast molds and use 2020 daily. i have no complaints about the stability of mastercam. my practices are not new and i still use the same paths i have for decades. when i do notice a crash it will be something annoying like a menu not functioning or a mouse click not working right. i haven't had a good close the program and back to windows crash in a long time.
    Sep 2009
    78
    I forgot to mention the really big snafu for us was back in 2017(?), MC changed something in the file structure such that many older operations would red check. At first we thought no biggie but then found out that MC would not allow those paths to be posted!! This is a well documented bug (MC called it a caveat) and support had zero solutions for us. Moving forward, any legacy files that red checked had to be regenerated just to post them. The issue has gradually calmed down thankfully, only because we're using less and less of the legacy files. As for the docs, the problems we are experience is min max Z's being off so we resorted to a 3rd party doc solution.
    The other problem we're having, and it's not a bug per se, is changing tool numbers seem to magically change some parameters. This should be a simple and quick task but for MC it really messes with our zen. Perhaps it's how we're using MC but all our MC programmers have 10-18 years experience and are very sharp so the latter probably isn't very likely.
    NX 10.0.3
    Nov 2017
    They are all stable.
    Stability of your rig and its capability are the real questions.
    Software gets more advanced every year and requires more from your computer. My issues with software crashes arise from a poorly built computer and/or a bad back-up power supply if you use one.
    Mar 2008
    683
    I am still upset when they changed the UI from V9 to X. Good by hotfingers.
    I am back on 2021 programming 5 axis machines with no issues.
    Apr 2003
    3578
    2022 is out and really stable.
    Cadcam
  1. Are new versions more stable than Sprutcam 7?
    By TXFred in forum SprutCAM
    Last Post: 01-08-2016, 06:20 PM
  2. CNC Programmer - Mastercam X versions - Texas
    By CNCenforced in forum Employment Opportunity
    Last Post: 12-22-2014, 06:23 PM
  3. Replies: 2
    Last Post: 04-10-2013, 07:24 PM
  4. mastercam x versions
    By riverracer in forum Mastercam
    Last Post: 08-05-2008, 04:58 AM
  5. mastercam x versions
    By riverracer in forum Post Processors for MC
    Last Post: 08-04-2008, 08:32 AM
