586,075 active members*
3,714 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > How to delay plasma cutter cnc mach3?
    Sep 2020
    Exclamation How to delay plasma cutter cnc mach3?
    Tell me, I have a CNC plasma cutter controlled by mach 3, I need to turn off the TNS 2 seconds before the end of cutting, can this be done through brains? if so how?
    Apr 2003
    540
    Re: How to delay plasma cutter cnc mach3?
    What is TNS? You can control anything that can be turned on or off via a relay by adding the correct code to your cut file. Software like Sheetcam can make doing so fairly simple.
  1. AngelBlade plasma cutter torch and plasma cutter consumables
    By Aaron Bruce in forum News Announcements
    Last Post: 09-16-2015, 08:52 AM
  2. Replies: 0
    Last Post: 09-09-2014, 10:09 AM
  3. MaxThor Plasma Cutter, the best choice of air plasma cutter
    By Steel Tailor in forum News Announcements
    Last Post: 09-05-2014, 02:53 AM
