586,069 active members*
3,612 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Abnormal behaviour of Fanuc series O-M controller.
    Hi everyone,
    I have Victor Vcenter V-65 cnc machine with fanuc series O-M controller. My cnc machine suddenly behaving abnormally. It started taking extra cuts and steps. I have changed the program several time but it didnt work. There is no alarm on the screen. Drives are working properly. Kindly help me to resolve this issue.
    Sep 2009
    99
    Re: Abnormal behaviour of Fanuc series O-M controller.
    Check if your ball screw couplings are slipping- that sometimes causes unpredictable movements.
    If you have belt drives for the axes, check if the pulleys are slipping on the ball screw/motor shaft.
    Is this happening on only 1 axis? or all axis? Change the direction of your program and see. Before opening to check the axes couplings, dial a part, perform some rapid movements in the air at 100% rapid rate, and then dial the part again to see if there is any position shift.
    I have changed the both direction and angle. But still same result. Not just one axis but all three axis behaving the same.
    Sep 2009
    99
    To understand the situation better, What is the extent of extra cuts? Is it very small or large? (Like 0.05-0.1mm or 1-2 mm type?)
    If you dial a component is the original reference matching thereafter or is there any shift?
    If the reference doesn't shift, then you need to check setting such as corner override, constant velocity mode and exact stop mode. These are all controlled by G codes.
    Cuts are large more then 2mm. Difference I am facing not specific. Everytime I run the program machine behave differently. But reference or machine zero remain the same.
  1. Help with Fanuc 0 series controller
    By destroyer125 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-27-2016, 10:54 AM
  2. Replies: 2
    Last Post: 05-30-2014, 07:05 PM
  3. Fanuc Series 31i controller question
    By pwilson101 in forum MetalWork Discussion
    Last Post: 09-15-2012, 12:44 AM
  4. GE Fanuc Series OM Controller
    By otto.wilcken in forum Fanuc
    Last Post: 03-14-2012, 02:27 AM
  5. GN6 Series Fanuc Controller
    By CBMach in forum Fanuc
    Last Post: 08-16-2005, 01:46 AM
