586,119 active members*
3,651 visitors online*
Results 1 to 6 of 6
    Sep 2005
    31
    Simodrive Problem
    Hi Everybody,
    I have the problem with SIMODRIVE ( SIEMENS ) model 6SC6140-0FE01 when I start to move axis the table hunting and move slow and then alarm occur.I tried to check power transister,FET on the PCB but I can't find the part problem.I hope somebody can help and please advice to me how to check.
    Nov 2006
    925
    The part number you have quoted is for a power card from a Siemens 610
    servo drive.First of all swap this card for one from another axis and see if the problem moves to the other axis.If it does not I would suspect the N board that controls the board you think you have the fault on.I suppose you have checked the commutation feed back cable and the encoder/cable.You can also swap these cables about to see if the fault moves.I have a lot of these drives and have had my share of problems with them over the years but have found that the 1FT5 motors are very reliable.95% of the problems I have had have been the G and N boards.If you have a spare axis position on an N board try moving the motor feedback onto that,you will also have to move the ribbon cable.I have a pdf for these drives which I can email to you if your mailbox can accept a large file.You can also download documentation from the Siemens site but is a hard site to navigate and I can`t remember if the 610 manuals are still on it.
    Mark
    Sep 2005
    31
    Thank you for your advice. I had to change anothers board and the problem is occur to anothers axis.I'm sure the problem is on this card.But I don't have any idea to check on this card.Do you have any idea?Please advice to me.
    Nov 2006
    925
    I`m sorry.I have never had a problem with one of these cards.I have a manual for this drive which might help.Do you have an email address?
    Mark.
    Sep 2005
    31
    Thank you very much for your assitance and my e-mail address is [email protected]
    Waiting for your document.
    Thank you again for your assitance
    Nov 2006
    925
    Wanchai,I have put a pdfof the Siemens 610 drive on my website and emailed you the link to download it from.
    Good luck.
    Mark.
  1. What's my Problem?
    By barnon in forum DIY CNC Router Table Machines
    Last Post: 06-05-2007, 04:28 PM
  2. problem with g90/g91
    By thesaent14 in forum Mach Mill
    Last Post: 04-28-2007, 08:14 PM
  3. problem
    By kiethnt in forum Uncategorised CAM Discussion
    Last Post: 03-27-2007, 08:32 PM
  4. Problem
    By impact in forum Xylotex
    Last Post: 03-12-2006, 07:53 PM
  5. IC problem
    By Muzzakkir in forum CNC Machine Related Electronics
    Last Post: 07-18-2005, 04:53 AM
