586,061 active members*
4,308 visitors online*
    Nov 2011
    13
    upgrade 100watt co2 laser to metal cutter
    hello, i own a 100watt co2 laser and i was thinking to upgrade the machine to cut some thin metal with it. now dont know much what should i look for , any suggestion what to buy for an upgrade to replace the main head. how to install or retro fits to co2 laser machine. i know i will need to add oxygen or nitrogen to cut metal. can i use the same air-line to push in the gas or not??
    the laser machine its a generic Chinese machine 1000x900mm , rdworks software , ruida 644 board, 100 watt tube, power supply output 40kv to laser tube.
    thank you for any input.
    Jun 2014
    22
    Re: upgrade 100watt co2 laser to metal cutter
    Sorry, but the answer is simple. No. A metalcutting CO2 laser has a completely different head and controller system. Also the assist gas (probably O2) will need high-pressure piping, valves, solenoids etc. Then there is the focus system and much much more.
  1. 150 Watts CO2 laser upgrade from non-metal to metal cutting
    By Miron.Costin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-24-2017, 11:12 AM
  2. 150 Watts CO2 laser upgrade from non-metal to metal cutting
    By Miron.Costin in forum Laser Hardware
    Last Post: 02-23-2017, 01:50 PM
  3. Mixed laser cutter for thin metal and thick non-metal materials
    By stylecnc in forum News Announcements
    Last Post: 04-18-2016, 01:45 PM
  4. Laser Cutter Upgrade
    By jazz352060 in forum Australia, New Zealand Club House
    Last Post: 08-05-2015, 03:36 AM
  5. Thin metal laser cutting machine- CHEAPEST metal laser cutter
    By Gweikelasers in forum News Announcements
    Last Post: 03-06-2013, 10:08 AM
