586,121 active members*
3,156 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCAD CAM V33 Just Released!
Results 1 to 7 of 7
    Mar 2012
    1570
    BobCAD CAM released Version V33
    Available in the following languages:
    • English
    • Spanish
    • German
    • Turkish
    • Japanese
    • Czech
    • Portuguese
    Here are the Top 10 new options BobCAD has to offer.
    MachiningCloud Import
    Build tool assemblies and directly import them to BobCAD's tool crib or tool library. The new XML import options allows the import of 3rd party tool lists. MachiningCloud is the first partnership to take advantage of this new option making tool library customization easier than any previous version.
    Barrel Mills
    Barrel Mill Tools are now supported for 3, 4, and 5 axis toolpaths. Standard, Advanced, Tangent, Lens, Taper, Double & Section Barrel Mills are supported and come installed in BobCAD's tool library.
    Steep Shallow Operation
    Best target steep and shallow geometry with a single toolpath operation. Choose from planar or equidistant for shallow areas. This toolpath engine results in up to 6X faster calculation times.
    Probing
    BobCAD now supports probing, choose from 41 cycles to setup your tools, set your work offset or in process inspection.
    Hole Feature Recognition
    Automatically finds hole sizes and depths. Pre populates operations types with rules found in the customizable knowledge base. On the fly edits that allow users to override settings if needed.
    Corner Slowdown
    Feed rate option to ramp down cutting feeds on all, external or internal corners.
    Chip Breaking Cycle
    Use with roughing and finishing operations that forces a chip break by tool motion. Adjust the length of cut, time, or length of chip.
    Advanced Holes
    Design holes in 3D using point locations. User defined hole, counterbore, chamfer and threads sizes.
    Align to Coordinate System
    Move geometry into position from any orientation using a from and to UCS(user coordinate system) . Great for moving parts to zero that are on compound angles.
    View to Active UCS
    Normalizes views to the active user coordinate system. Making it easier to view and draw on different planes of geometry.
    To see all the new features use this link https://bobcad.com/products/whats-ne...rce=CNCZ_91520
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2009
    291
    Re: BobCAD CAM V33 Just Released!
    is probing available on the demo version of v33? do you have to have macro programs in the machine for your post to call out? just wondering how it works.
    Mar 2012
    1570
    Hello 1234567,
    Yes you can download a demo of V33 and try out the new features. Use this link https://bobcad.com/19/v33/?source=CNCZONEV33 The demo software doesn't post full programs, but you can request a trial license when you talk to an account manager.
    As far as the probing feature, yes your machine has to have the marcos to support the probing cycles. V33 has 41 probing cycles for tool setters and measuring. There are more cycles that most machines support.
    Download a demo and check it out!
    Al DePoalo
    Mar 2009
    291
    Ok thanks.
    Sep 2012
    76
    Al, the changes look really good! I like the chip breaker for the lathe, as well as corner slow down. I have two grips I'd like to share:
    1) Be really nice of Bobcad to send us a notice (as a support customer) when new releases come out. Just sayin'.......
    2) WEDM remains to be addressed, and it would be so simple and easy (I think). Some day??????
    Sep 2012
    76
    Quote Originally Posted by Wolfman2332 View Post
    Well That was cool....
    1) Bobcad called and said they were working on an email announcements, and 4 hours later I got it!
    2) They also spent 30 minutes discussing the WEDM changes that would help.
    I have spent the day exploring the new features (not all!), and can say they are great additions - esp the chip breaker and the corner slow down. These will be a great help.
    Mar 2009
    291
    does anyone have a post with probing set up? I cant find one on the bobcad support page.
  1. BobCAD CAM V32 SP2 Just Released
    By aldepoalo in forum BobCad-Cam
    Last Post: 04-24-2020, 06:07 PM
  2. BobCAD CAM V31 Just Released!
    Last Post: 09-02-2018, 06:27 AM
  3. Replies: 19
    Last Post: 11-05-2017, 08:11 PM
  4. EMC 2.2.4 released
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 03-18-2008, 05:57 PM
  5. Bobcad has a new patch released
    By HuFlungDung in forum BobCad-Cam
    Last Post: 06-10-2003, 05:04 PM
