586,070 active members*
3,390 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 2 axis motor coupler...
Results 1 to 6 of 6
    Oct 2011
    205
    Hey guys, anyone here ever replace the red plastic coupler between the motor and ball screw? I am having a hard time finding a replacement for the original ones that basically fell apart.
    Nov 2012
    1267
    Re: Arrow 2 axis motor coupler...
    Search for "spider insert". Those are common replacement parts, you just have to determine the correct size. Measure the diameter and look for any markings.
    Some time ago I had one of those failed in a vacuum pump. I CNC'd a temporary replacement out of PVC foam. Worked perfectly fine for a month until the real part arrived.
    Mar 2008
    285
    We can help you with the Spider, Contact Cincinnati Tech-Support at Fives-MSI. 1-800-934-0735 Tech-Support-Cincinnati.
    Oct 2011
    205
    Quote Originally Posted by gwood View Post
    I called Lissa in Canada a week ago and still no answer. Someone at your place called me and was looking into it for me yesterday. Hoping to hear back soon.
    Dec 2006
    584
    This is a LOVEJOY coupling, just buy a new complete coupling to get your machine running.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2011
    205
    Found a suitable replacement. " Lovejoy GS 24 Spider 98A Red"
  1. arrow 500 axis motor
    By larry180 in forum Cincinnati CNC
    Last Post: 08-02-2012, 01:44 PM
  2. need help arrow 500 y axis motor
    Last Post: 07-18-2012, 12:23 AM
  3. changing z axis motor coupler on the x4+
    By ataxy in forum Syil Products
    Last Post: 08-07-2009, 11:57 PM
  4. Motor Coupler's
    By SSfab in forum Benchtop Machines
    Last Post: 02-04-2009, 05:25 PM
  5. Coupler motor question
    By MagTDK in forum DIY CNC Router Table Machines
    Last Post: 08-07-2006, 11:37 PM
