586,508 active members*
3,300 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to Select a Drawing in mcx7
    May 2009
    1332
    I have a .dxf file which contains 28 small drawings and each drawing will fit on a 8.5”x11” sheet. I was told to select all, which I did and then separate them in printable pages.
    So after all are selected how I convert each drawing to a printable page?
    My knowledge in mcx7 is quite rusty, so please explain
    Nicolas
    Sep 2020
    14
    Re: How to Select a Drawing in mcx7
    Sounds like you have to window each drawing and use "save some" to save 28 different files and name them 1 thru 28? Then pull up each drawing seperate, fit all and print.
    May 2009
    1332
    Quote Originally Posted by GCSRT View Post
    I gave up on mc because I found the free AutoDesk DWG TRUEVIEW 2021 and now I have my prints. The truview 2021 is only to view and print .DWG or DXF and thats all I needed. Thanks for your time
    Nicolas
  1. Select multiple solids for use in verify - MCX7 ?
    By colton_m in forum Mastercam
    Last Post: 10-26-2015, 07:50 PM
  2. Transfering MCX4 tools to MCX7
    By dfearnow in forum Mastercam
    Last Post: 06-20-2015, 09:22 AM
  3. new drawing board --wicked size 44x60 drawing area
    By woodman08 in forum Logic Trace CNC/DXF
    Last Post: 02-08-2015, 12:58 AM
  4. Replies: 1
    Last Post: 01-25-2015, 03:33 AM
  5. MCX7 optirest, core mil passes
    By Master Miller in forum Mastercam
    Last Post: 12-17-2013, 05:26 PM
