586,035 active members*
3,666 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Alarm 2010 Fanuc 18-T, Suggestions?
    Oct 2006
    15
    Daewoo Puma 200S running a Fanuc 18-T, machine ran fine the night before and the next morning we get a 2010 alarm "Spindle Rotation Is Abnormal". Power it off and restart it doesn't help, the hydraulic pump will come on and run about 5 seconds then shuts off. Any suggestions? Thanks!
    Jul 2005
    380
    Re: Alarm 2010 Fanuc 18-T, Suggestions?
    Check incoming voltage. Also check for popped breakers.
    May 2016
    526
    Check 24v supply if hydraulics shutting down possibly due to lack of signal that they are on.
    The encoder requires 24v to activate as well
  1. Replies: 1
    Last Post: 08-18-2020, 08:21 AM
  2. Replies: 5
    Last Post: 11-19-2017, 06:32 PM
  3. 2010 doosan 2000sy fanuc 31i
    By positiverake in forum Daewoo/Doosan
    Last Post: 02-14-2017, 10:43 PM
  4. Doosan 2000sy fanuc 31i (2010)
    Last Post: 02-02-2017, 12:32 AM
  5. 2010 Tool Not Available - Fanuc Om
    By PPM in forum Fanuc
    Last Post: 08-24-2005, 09:22 PM
