586,067 active members*
5,119 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Why does this program make the machine crash? - with video
Page 7 of 7 567
Results 121 to 139 of 139
  1. #121
    15362
    Re: Why does this program make the machine crash? - with video
    Quote Originally Posted by Superman View Post
    No he hasn't.... read his posts again
    Trying to apply cutter compensation in the Z axis move is not going to happen
    Mactec54
  2. #122
    Aug 2020
    95
    I think you are confused as to what and how tool comp works, on a 3 axis machine like yours only the X an Y axis can use tool comp
    You machine does not have Tool length compensation in the Z axis, it only has tool offset and a wear adjustment for the Z axis
    OK, so it seems there is some confusion over tool length compensation and tool offset and wear adjustment. I didn't know there was a difference between 'tool length compensation' and 'tool offset'! Anyways, my machine has only a set of 128 offset (labelled 'length' from memory), length wear, diameter and diameter wear settings.
    The offset applied by H is the tool length/offset + the length/offset wear. For the purpose of this conversation, I am only talking about tool length offset. I am not talking about any sort of diameter or automatic tool shape compensation or wear correction. Just the tool length offset applied by H.
    When I use tool length offset (G43 Zx Hx) it works exactly as expected for everything in XY plane (G17). It also works as expected for the start and end point of an arc in G18, it does not work for the center point of the arc, causing an impossible arc.
    I have not spent any more time playing with this on the machine recently as have spent the last while removing a broken tap from one of the spindle drive lug bolts. It was a gift with the machine, M3 tap broken flush that had to be drilled out from below! Got it out last night without even scratching the thread...
    Also, I am waiting for the manual before doing much more...
  3. #123
    Dec 2008
    3109
    Quote Originally Posted by ashes-man View Post
    I would check your programming again.... you did have the arc centre to arc start point programmed incorrectly.(IK values)
    These issues must be fixed before any trying any tool comp trials.... you end up not knowing what is causing problems.
  4. #124
    15362
    Which I don't think your control can do, it appears that your control is working as any 3 axis machine should, best wait and see if the manual can show anything different
    Mactec54
  5. #125
    Aug 2020
    95
    OK, you are the first person to mention this! Can you please elaborate? My test program is in the attached pdf for reference.
  6. #126
    Aug 2020
    95
    Yep, keen to get that manual. I had another surprise tonight where I found out that a G53 uses tool length offset! All the other manuals I have read say that a G53 will cancel tool length offset. The program I was running has a G53 Z0 after each operation. This causes a Z axis soft limit. I changed them to G49 G53 Z0 and all was good. So, yeah, really want that manual to start understanding this machine better.
  7. #127
    Dec 2008
    3109
    double post
  8. #128
    Dec 2008
    3109
    I may be in error..
    I pictured a G3 being a CCW move putting the centre on z0 plane... your pic shows a CW arc with centre below the start point
    Arc sweep direction is when viewed from the plus side of the of the third axis ie... XZ so view from Y+ side.
    G53 is to "single shot" use the machine co-ord system. Which cannot be moved. I suppose you could have active compensations show thru on all work co-ord systems.
  9. #129
    15362
    Try it with G0G53Z0 this is how it should be used, if it does not have a G0 before it, G49 will cancel the tool offset and you don't want to do that unless you have to
    Mactec54
  10. #130
    15362
    I may be in error..
    Post #36
    Mactec54
  11. #131
    Jan 2007
    146
    I am not a machinist or g-code expert, but we have a huge Quickmill that does the same thing when we use the right angle head. We found out the hard way we need to program in a safe move in the different planes because the right angle head offsets are not used until after the first move. Could this be the problem?
  12. #132
    15362
    Quote Originally Posted by jschmitt View Post
    No you have a completely different setup when using a 90 degree head, which needs to be positioned before any axis moves
    Mactec54
  13. #133
    Aug 2020
    95
    I woulld be keen to hear more about this problem and any code examples that you may have where it went wrong!
  14. #134
    Aug 2020
    95
    So... the manual turned up for my machine. Quite a comprehensive manual about everything except g code programming. A huge section on what all the buttons do and a huge section on macro programming (disabled option on my machine) and about 10 pages on g code. Oh well, it was a gamble I guess. The pages relevant to this discussion are attached. There is no mention of tool offset behavior for arcs or different planes at all. Just that "The program designated ending point of Z axial movement can be shifted through the previously set offset dimension in the positive or negative direction".
    The manual did answer some questions like what my mystery buttons do, why a G83 drill cycle was repeated multiple times (K means number of repeats) and confirmed that only a Tx command is required for a tool change (i.e. a tool preselection generated by the post processor would cause a tool change).
    So, unless the local Mazak tech can find time to look at it for me, I am out of options. So far the consensus from everyone I have spoken to except this forum is that there is some sort of software bug in this machine.
  15. #135
    Jun 2010
    4256
    It may not be an actual 'bug'. It may simply be a limitation of the hardware controller.
    Very old CNCs had these great big PCB boards with hundreds of chips, just to do the most basic control. In effect, although they did not think of it that way back then, they were trying to build a limited-function CPU. Trouble is, some functions were just too complex for the hardware. I seem to recall that on some machines you had to pay extra for an extra PCB to implement the g2/g3 commands.
    All this has been rendered obsolete by the use of a PC as the controller. It could be running Mach3, Mach4, UCCNC, LinuxCNC or several other PC-based programs. The huge difference is that with a modern PC, it is no trouble at all to have the SW run 6 axes synchronously. It's just software, running on a 3 GHz processor with 6 GBytes of memory!
    We do have a similar problem with some of the external pulse engines from China. They try to emulate an ESS, but they miss out on certain g-code instructions. Probing is a notorious example.
    Cheers
    Roger
  16. #136
    15362
    So it is just like any other standard control which I was saying before, what you where trying to do is not standard programing and your control can not do what you wanted to do, there are some ways to do some creative programing to make it follow the path you want, but just for an exercise that is an unpractical move it is not worth the trouble
    So for the basic arc you need to use I & J value with no K or you could try the R value if the control supports it
    Mactec54
  17. #137
    Aug 2020
    95
    See that is where the disagreement is. Everybody else and all my testing says that any standard controller should be able to perform this operation.
    My controller does support R but it does the exact same thing as using I/J and K. The actual problem is that the arc end point is Z compensated for tool length, but the center point is not.
  18. #138
    Aug 2020
    95
    Quote Originally Posted by RCaffin View Post
    Cheers
    Roger
    Haha, yeah I have seen one of those old hardware based controllers. This controller is not that bad. It runs on an Intel 486 CPU. It can do some of the more complex operations like helix milling, rigid tapping etc. It can perform arcs in every plane, but just forgets to correct the arc center if tool length offset is used when performing an arc in G18/G19 planes. I also have a mach 3 based router which I have a love/hate relationship with!
  19. #139
    15362
    Everybody else has not done on your machine and using your control, what you wanted to do which is non standard for your machine
    The Z is not compensated and there is no way to do that on your control
    Mactec54
Page 7 of 7 567
  1. Replies: 35
    Last Post: 04-25-2017, 09:56 AM
  2. program crash
    By Cartel, LLC in forum BobCad-Cam
    Last Post: 05-26-2013, 09:17 PM
  3. Make Machine Beep During Program?
    By behindpropeller in forum Haas Mills
    Last Post: 12-13-2011, 07:43 PM
