586,356 active members*
2,987 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > GRBL alarm 8 after the first hit on X limit switch
Results 1 to 6 of 6
    Sep 2015
    43
    Hi yall!
    I have tried for hours to solve this nut scratcher:
    When homing Z does fine. X gets alarm 8 (failure to clear the endstop) after the first, faster search. I have them set normally closed, and $5=1.
    Otherwise Z and X switches are supposed to be similar, but the homing direction is inverted for X (and Y, at the moment - will change their switches to max positions) thus $23=1.
    I measured the resistance of both Z and X switches and their wiring from the RPI CNC board's endstop connectors - everything looks to be fine and similar for both: Normally the pins are grounded, 5V between gnd and endstop connector's pin when triggered.
    I have no idea what might be the solution - maybe I have a dorky mistake that I just don't get by myself. Noise it most probably is not, because I have shielded cables (grounded in the PSU end) and the alarm always comes when the pull of movement is done. I tried a longer pull off (2cm off of the switch), same result.
    Would pull down resistors solve this? Doesn't the RPI CNC board have pull up resistors? Can I add pull downs on top of the existing pull ups?
    So weird that the Z works perfectly at the same time.
    I do have A and Z limit switches connected in series because I have enabled the auto squaring homing, but I am still far from getting to wrestle with Y and A homing
    Any advise appreciated!
    Mar 2015
    410
    Re: GRBL alarm 8 after the first hit on X limit switch
    This means that after retracting, the limit switch is still active.
    Increase the retract distance (pull off distance) ($27 on grbl)
    Sep 2015
    43
    Quote Originally Posted by hfjbuis View Post
    Pls read before answering. I put 20mm already, and I know what it means. What is a mystery is how to fix it.
    Oct 2014
    I know this is a 6 years old thread, but it describes exactly what is happening to my cnc today. Did you ever found the mistery?
    Thank you very much,
    Oct 2014
    I just noticed that the post is not that old, 2015 was the joining date of PropellerHat. Getting old, need better glasses :-D
    Oct 2014
    Problem fixed:
    Just in case somebody goes through the same issue, the solution in my case was to replace wiring of the X-limit switch with a shielded cable.
    Regards
  1. 2030 limit switch alarm
    By jschmid in forum Fanuc
    Last Post: 12-10-2022, 04:31 AM
  2. Limit switch setup, grbl/candle.
    By ca280 in forum G-Code Programing
    Last Post: 10-30-2019, 08:21 AM
  3. Z limit switch alarm
    By guydrisc in forum Okuma
    Last Post: 01-22-2012, 06:29 AM
  4. X Limit switch '92 VF-0 103 Alarm
    By lkenney in forum Haas Mills
    Last Post: 07-05-2010, 04:57 PM
  5. TM-1 Y axis limit switch alarm
    By jwknow in forum Haas Mills
    Last Post: 10-26-2007, 09:53 PM
