586,307 active members*
3,330 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > collision in simulation
    Feb 2009
    214
    I have this exact same problem everytime.
    I make small molds for fishing lures and the collision happens at the end of the hook. everymold has a different hook, not the same file, but drawn the same way. the hook is drawn using a spline and then doing a sweep of the profile,
    this is only a 2 axsis profile cut.
    I have looked at top of part, top, of feature. I have looked at the tool overall length, protrusion length.
    while there is no problem when machining this, I would like to fix it,
    the error message is always always the same.
    David L. Aery
    www.hooksolutions.com
    Feb 2009
    214
    Re: collision in simulation
    Ok, here is what happens. I have made a small change to the geometry, not where the collision takes place and now it works fine. the change I made was not to fix this problem and don't see why this would make a difference other than made a change.
    David L. Aery
    Feb 2009
    214
    ok different day no changes and the problem come back.
    anyone have any suggestions?
    David L. Aery
    Dec 2013
    5717
    While the message is irritating, if the part runs OK, then just ignore it. I find Fusion 360 indicates a collision sometimes when I know there is no collision possible in a given operation. I'm sure BobCad makes the same type of errors.
    As best I can tell, Fusion 360 gets confused about material removed in a previous operation and thinks the material is still there. Maybe BobCad does the same thing.
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2009
    214
    thanks, the problem has just started in the past 3 weeks. the only thing I have done different is have been adding a couple of new tools.that may be when it started.
    David L. Aery
  1. torch collision yet no collision
    By klineplasma in forum Hypertherm Plasma
    Last Post: 09-03-2020, 02:55 PM
  2. Replies: 1
    Last Post: 05-29-2016, 02:08 PM
  3. sim collision
    By LeWhite in forum BobCad-Cam
    Last Post: 09-24-2014, 01:12 AM
  4. Replies: 2
    Last Post: 08-08-2011, 05:01 PM
  5. Help heidenhain collision
    By Gearhead123 in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2011, 12:16 PM
