586,103 active members*
3,557 visitors online*
Threaded View
    Nov 2016
    5
    Ball screw maintenance
    Hi there,
    I have a second hand cnc machine that I'd like to do some maintenance on. I've read that the ball screw needs greasing routinely. I have these ts1610 nuts that I can't any info on (the closest I've found are sfu1610 ball screws).
    There are 3 holes on the side of the mounting flange- 2 small and 1 large. I'm guess the large one is where the grease will enter (see pic 2 below)? It's an m5 thread so I was going to buy a few m5 grease nipples along with a grease gun. Can anyone tell me if this is a good assumption?
    Does anyone know what the 2 smaller holes are for (see pic 3 below)?
    Finally, could anyone tell me which grease to use? I'm going to spray white lithium grease on the screw threads itself. Shall I get a pot of this and pack it inside the nut too?
    cheers guys,
    Nic
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Ball nut arbor size for 1605 ball screw
    By kdoney in forum MetalWork Discussion
    Last Post: 04-08-2020, 07:45 AM
  3. Adding ball screw to lathe for Electronic Lead Screw
    By harrzack in forum Hobbycnc (Products)
    Last Post: 12-28-2018, 03:28 PM
  4. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  5. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
