586,103 active members*
3,805 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > axbb-e with Huanyang VFD
Page 2 of 2 12
Results 21 to 33 of 33
  1. #21
    24221
    Re: axbb-e with Huanyang VFD
    BTW, here is something that many have used as a guide and is a set up for disaster and has caused shorted outputs of the BOB etc, causing the relay to stay on.
    The PDF shows a 20amp relay to operate a VFD ~20ma input!
    But the significant error is there is no BEMF diode fitted across the relay coil.
    When a relay such as this opens, there is a very large BEMF which can be in the order of several hundred volts.
    The output device is usually either a mosfet or by-polar transistor, the rating of which is generally typically ~60vdc.
    This can, and has, resulted in the shorting of the output device causing the relay to stay on.
    Al.
    Albert E.
  2. #22
    15362
    Al.
    Correct if this was a coil operated Relay, I advise anyone to use solid state Relays, which almost all have the diodes built in so no need to fit another one, it does not matter what size the amp rating of the SSD either, they are only being used as a switch simple ON / OFF to control a VFD Drive FWD control, they come in the same form package size, Just pick a quality SSD like Opto 22 or similar
    This can not cause any kind of shorting of the output device if you use a SSD, I have been using them this way for more than 30 years and have never seen one fail, because of a short from switching, have some currently on my own machines which are over 15 years old and are still working as when they where installed
    Coil operated Relays are a relic of the past SSD is the only Relay any new builder should be using
    Mactec54
  3. #23
    24221
    So is this an about face of post #14???
    Also many of the Chinese BOB's include a mechanical relay to operate the FWD operation of the VFD.
    Albert E.
  4. #24
    15362
    Not at all
    Correct and they work fine most are already protected, some are not, but cause no problems, also they are not a relic, like what is used in the Homann design, ( 48v Coil ) so don't cause any VFD Drive connection problems with this type of switching, I have tested most of, even the cheapest $5 Breakout Boards that have built in relays and if they work, don't cause any problem for VFD Drive switching
    Mactec54
  5. #25
    24221
    Doesn't matter what (mechanical) relay is used, it is imperative to fit the reverse diode when fed from a solid state device.
    Even if not, due to noise imposed issues.
    If the relay is built in to the board, then it should normally have the diode.
    I am referring to the likes of G540, that some (unnecessarily) use a external relay as shown on the Homann diagram.
    Albert E.
  6. #26
    15362
    Most Solid state SSRs already have that protection so a diode is not needed, and if you wire correctly you don't have a noise problem which I have proven many times
    The Homann Design is just one of many that have used a similar wiring diagram to use Relays, any one that uses a Relay with the G540 has experienced false starts which have happened with many G540 installs but not everyone is using a G540 there are a lot more that just use a regular Breakout Board and stepper Drives
    Mactec54
  7. #27
    24221
    There seems to be some confusion as to the Description Relay, RELAY, although a little vague, is commonly used among electrical/electronic personnel to mean a mechanical coil operated device when referred to this way..
    If a solid state version is referred to, the term SSR or Opto relay should be used..
    Essentially the interface I suggested is the same technology used in a SSR/Opto, just it does not have galvanic isolation.
    Which in practically all situation is no problem due to isolated supplies used.
    Just simply enter 'Relay' into Google and see what comes up.
    Albert E.
  8. #28
    15362
    Every Manufacture calls a SSR a Solid State Relay, galvanic isolation Great word, and what most systems lack hence the need for a Relay of some kind you choose what you want to call it, or use to do the job
    Mactec54
  9. #29
    24221
    Yes, SSR IS a Solid State Relay.
    I was referring to the word 'Relay' in the accepted general sense, when used on its own with no other reference, where it is universally acknowledged to mean the electro-mecanical kind.!
    Albert E.
  10. #30
    15362
    Hey Al this is a mostly hobby forum and adding Tec terms is not needed, when someone writes Relay they then will know what that is, and can choose what type they want to use, or can ask if you want to get technical so no one can under stand that is fine by me, you must remember that most don't know the basic's of any type of electrical installation, but they get by with simple instructions
    Mactec54
  11. #31
    Dec 2019
    I am massively confused by all this discussion. I thought Huagang vfd's can be controlled only by a 0-10v output, just one. 0v is off, 10v is full speed. No forward signal needed.
  12. #32
    Nov 2013
    4375
    Mostly. The speed control is, as you say, 0V-10V, but you also require a set of relay contacts to turn it on.
    Another means of controlling a VFD is by Modbus. Unfortunately early Huanyang VFDs had a non-standard Modbus protocol implementation. Some enterprising souls had made a plugin
    that converted the standard Modbus to the Huanyang version....but it was a bit hit an miss. In recent years all Huanyang VFDs have a genuine Modbus compliant protocol.......so you can control the VFD
    by either method (conventional:0-10V plus relay contacts OR Modbus).
    Craig
  13. #33
    24221
    Quote Originally Posted by ian8555 View Post
    See the pic in the OP of the terminals, FWD & REV.
    Albert E.
Page 2 of 2 12
  1. UCCNC & AXBB-E combo
    By peteeng in forum Australia, New Zealand Club House
    Last Post: 06-02-2020, 01:14 PM
  2. New build using AXBB-e and huanyang vfd
    By Chmexdf5633 in forum Spindles / VFD
    Last Post: 04-14-2020, 01:42 AM
  3. Its Aliveeeee my AXBB-E is working
    By curiosity22 in forum Australia, New Zealand Club House
    Last Post: 01-31-2020, 01:39 AM
  4. my AXBB-E and UCSB are on the way, small annoyance is anyone using axbb with mach3?
    Last Post: 05-17-2019, 03:50 AM
  5. New AXBB controller
    By ger21 in forum UCCNC Control Software
    Last Post: 03-20-2019, 11:55 PM
