586,113 active members*
3,198 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need mill to feed hold when door opens
    Mar 2018
    8
    I have a Agma VMC with a 0i-MD control. When the door is opened the spindle stops but the axis keep feeding. Does anyone know what parameter or keeper will also put the machine into feed hold?
    Re: Need mill to feed hold when door opens
    Can you post your ladder? Coil G8.5 in the ladder need to turn off with the door open.
    Mar 2018
    8
    Quote Originally Posted by drdos View Post
    Here is a screenshot of G8.5 in the ladder
    Quote Originally Posted by ONyX557 View Post
    There could be a Safety door switch like D4NL-1DFA-BS-F OMRON, maybe you can disable it.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Jan 2014
    106
    Quote Originally Posted by cncmakers001 View Post
    why would you disable it?
    You need to know when the door is opened to accomplish what he is asking " to feed hold the machine"
    DRDOS has it correct.
    But can you back up the logic and send it to us or attach it.
    The photo does not show enough to help you.
  1. Haas OM2A Door Open Door Hold
    By kaymteo in forum Haas Mills
    Last Post: 07-29-2020, 03:28 PM
  2. Replies: 3
    Last Post: 04-03-2018, 06:05 PM
  3. (FANUC 0i) Wanna stop high pressure when the door opens
    By jaeohck in forum CNC Swiss Screw Machines
    Last Post: 10-19-2017, 08:32 PM
  4. Bypassing door hold and door locks on 2011 VF?
    By locash in forum Haas Mills
    Last Post: 04-05-2012, 04:31 PM
  5. Door Feed Hold
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-12-2006, 03:45 PM
