586,060 active members*
4,345 visitors online*
IndustryArena Forum > CAM Software > Alphacam > ERROR User variable not declared MOVE_NEEDED
    Sep 2020
    3
    Hi Guys,
    Keep getting this error when trying to output NC Code in Alphacam! Cannot find anything in there help menu!!
    Any ideas
    Apr 2015
    327
    Re: ERROR User variable not declared MOVE_NEEDED
    Variable MOVE_NEEDED inside postprocessor code is not declared.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    Apr 2010
    89
    Open the Post in AlphaEdit for editing then search for $1000 section of the Post then make a new line under the $1000 line with the following code
    MOVE_NEEDED (6,0,0)
    then save post and then re-select the Post in AlphaCam Mill or Router which ever you are using.
    The (6,0,0) is for Integer Format with no leading or trailing zero's, I'm assuming by the name of the variable that it's just an On or Off variable either 1 or 0,
    if it needs another format use ( ) for numbers similar to XY and Z Axes Format or (" ") for Text Format.
    Aug 2020
    10
    Hi Frank . I dint mean to bother you. I have a Cr Onsrud /osai10 router i would like to get working and would like to use it with mastercam 2019 but cannot find a post program for Osai. I tried to edit the Fanuc version with only limited success. I have a technical background but i am new to CNC. I think I could manage edits on an Osai post processor Or something close. Do you think you could help me. Any kind of help would be appreciated. Thanks Kevin
  1. Monitor a user-created GCode variable in CNC-Lite
    By serickson in forum CamSoft Products
    Last Post: 11-16-2018, 12:17 AM
  2. Tool prep number into user variable
    By Lomach in forum LinuxCNC (formerly EMC2)
    Last Post: 07-22-2012, 10:30 PM
  3. Error when trying to set variable
    By tonper in forum G-Code Programing
    Last Post: 03-17-2009, 02:12 PM
  4. User input variable - best way?
    By markkirby in forum G-Code Programing
    Last Post: 06-02-2008, 03:02 AM
  5. variable subscript out of range error
    By hideaway in forum G-Code Programing
    Last Post: 03-15-2008, 06:57 PM
