586,069 active members*
3,403 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Help finding VFD for Spindle
    Sep 2019
    6
    I purchased the following Chinese spindle motor, and got some bad advice on the VFD. The VFD is a KBMA-24D series from KB Electronics, which is obviously incompatible because it will not source 400 Hz.
    The motor I have uses German bearings and claims low runout. The specs are:
    Product information
    Technical Details
    Manufacturer: Taishi
    Part Number: USTS0811FG
    Is Discontinued By Manufacturer: No
    Color: Silver
    Material: Steel
    Power Source: Ac
    Voltage: 220 Volts
    Wattage: 800 watts
    Horsepower: 1 hp
    Engraved on motor: 0.8KW 220V 6.5A 400HZ
    The VFD the Rep now suggests, again, does not source 400 Hz, and costs nearly $400, so I thought I'd try getting advice from the forum. I would prefer running the VFD with 120V/60Hz input voltage if that is all possible, but if not I can drop another 240V line in my shop. I have a limited budget so I don't want to end up with another VFD that doesn't drive this motor.
    Aug 2015
    13
    Re: Help finding VFD for Spindle
    have you seen these? https://www.amazon.com/dp/B0775XWYVJ...ing=UTF8&psc=1
    i'm not an expert but it can do 400hz and should be able to manage the 800w.
    i had one for my 2.2kw spindle but it wasn't big enough so i ahve gone with a 220v version
  1. edge finding with chinese spindle (6000 rpm min)
    By QuinnSjoblom in forum Spindles / VFD
    Last Post: 02-21-2018, 07:33 PM
  2. Replies: 7
    Last Post: 12-03-2014, 10:46 PM
  3. Trouble finding / looking for spindle motor for homemade CNC
    By bastinka in forum DIY CNC Router Table Machines
    Last Post: 05-09-2014, 01:06 AM
  4. Finding spindle tool number on Fanuc OiMD
    By yaji63 in forum G-Code Programing
    Last Post: 09-17-2012, 11:12 AM
