586,094 active members*
3,904 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > The 3d router for furniture processing
    Feb 2010
    202
    Hey, I recently built a machine for a customer.
    This is a 3d router for furniture processing. The working area 2100x3000 mm's, base made of 150x250x8 profile, machined bases, Hiwin 35 linear guides, Atlanta HPR Module3 helical gears, drives through leadschine servo, longitudinal axis 2 kw, x and z 0.75 kw plus planetary gears, HSD spindle 9kw ATC, tool magazine for 8 pcs - maltanese gearbox, csmio ip-s control unit, counterbalance actuators for z axis, magazine pushback actuator, pins for fixing the material on the table, dust extraction, Becker 5.5 kw pump, some desktop for a mach3. A lot of protection in case of a collision, 6-section pressure table.
    So, to not talk too much, I'm presenting pictures and some movies.
    https://youtu.be/2HmWvgddi64
    https://youtu.be/Kb4Y3wQ4-kg
    Jan 2020
    39
    Re: The 3d router for furniture processing
    Wow! Nice build.
    Did you have that Y axis (long axis) tube machined for mounting linear rails? And how did you attach it to the main frame?
    Do you think those 2kw servos are a bit of an overkill for this machine? I am making a smaller router and my gantry will be over 150kg and I'm thinking about using 2x 750w servos...
    Sent from my SM-G970F using Tapatalk
    Feb 2010
    202
    The side bases for the Y axis are machined and bolted to the main frame. In addition, the y axis is driven by one shaft located in the crossbeam and one servo motor.
    The machine has great dynamics and there is no shortage of torque.
  1. Replies: 0
    Last Post: 02-17-2020, 10:36 AM
  2. Professional wood CNC router for furniture
    By RoseChina in forum News Announcements
    Last Post: 03-27-2013, 08:53 AM
  3. LIMAC 2-head CNC Router for furniture factories
    By limacchina in forum Uncategorised WoodWorking Machines
    Last Post: 07-04-2011, 06:39 AM
