586,121 active members*
3,485 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360 IN ACCURATE CUT. How to fix?
Results 1 to 9 of 9
    Mar 2020
    60
    Smile Fusion 360 IN ACCURATE CUT. How to fix?
    hey,
    I seem to have some serious problem making some cuts with using 360.
    First cut is accurate second cut is not.
    I have tried three different samples each of the samples first cut 30.50mm and after the final cut 34.29mm A perfect cut on all three samples. On the saying sample there’s a second cut which is 59.52mm and after the final cut I guess 64.86mm it has extra cut of 5.34mm which is throwing off the 59.52mm cut. I am completely lost and I’m not sure what to do infusion fusion 360 on each of the three samples I was doing a cut at 59.52mm I’m either getting +5.2mm or -7.4mm I tried to compensate for the extra 5.2 m on the first sample but after the cut I got 64.7mm. He is so in accurate it is so confusing and frustrating I’m not sure how to fix it all what’s going on I’m cutting acrylic plastic 1/4”. And 1/2”. If I try to do this car and wait both cars so accurate if I try to do these two cars on aluminum both of them accurate. The problem occurs when I’m trying to cut a acrylic plastic. If anyone’s have any suggestions or any idea how to fix us I would really appreciate it the help.
    keep in mind I am just learning how to use fusion 360.
    Picture sample.
    Nov 2014
    724
    Re: Fusion 360 IN ACCURATE CUT. How to fix?
    Export your f3d file so we can take a look at it. You'll probably have to zip it so it can be uploaded.
    David
    David
    Romans 3:23
    Etsy shop opened 12/1/17 - CurlyWoodShop
    Mar 2020
    60
    ok,
    i upload it as rar file
    Attached Files Attached Files
    Nov 2014
    724
    Not the nc file, the f3d file from F360. Go to file, export, choose a place on your computer, give it a file name, then save it. Upload that file.
    David
    David
    Romans 3:23
    Mar 2020
    60
    ok. i did .f3d under autodesk foolder.,
    which one, theres a list .f3d file about 30 file .
    Mar 2020
    60
    Sorry, Don'r mean to sound stupid. how to locate f3d file. please explain with more detail.
    thanks
    Nov 2014
    724
    File - Export - f3d
    Here's an article if you need it - https://knowledge.autodesk.com/suppo...usion-360.html
    David
    David
    Romans 3:23
    Mar 2020
    60
    ok, thanks
    upload now
    Mar 2020
    60
    (Spelling correction)
    """ First cut is accurate second cut is not.
    Have tried three different samples each of the samples first cut 30.50mm and after the final cut 34.29mm A perfect cut. On all three samples. On the same sample there is a second cut which is 59.52mm and after the final cut,
    I get 64.86mm, and it has an extra cut of 5.34mm which is throwing off the 59.52mm cut. I am completely lost and I’m not sure what to do in fusion 360 on each of the three samples. I was doing a cut at 59.52mm I’m either getting +5.2mm or -7.4mm I tried to compensate for the extra 5.2mm on the first sample, but after the cut I got 64.7mm. It's so inaccurate and confusing. I'm frustrated. I’m not sure how to fix it. I’m cutting acrylic plastic 1/4” And 1/2”. if do these cut on aluminum both of cut's are accurate. The problem occurs when I’m trying to cut on acrylic plastic. If anyone’s have any suggestions or any idea how to fix, I would really appreciate it the help."""
  1. Accurate CAD for all your CAD/CAM/CAE Needs
    By accuratecad in forum Manufacture Company Listing
    Last Post: 10-27-2016, 12:06 PM
  2. it is not accurate yet
    By sml2010 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-07-2013, 03:46 PM
  3. What is more accurate
    By cncadmin in forum DIY CNC Router Table Machines
    Last Post: 06-07-2007, 11:49 PM
  4. What is the most accurate CNC?
    By cooler21 in forum Commercial CNC Wood Routers
    Last Post: 03-25-2007, 01:27 PM
  5. How accurate?
    By bearwen in forum Commercial CNC Wood Routers
    Last Post: 02-19-2006, 03:07 PM
