586,070 active members*
3,521 visitors online*
    Dec 2018
    Extra Circles In Mach3turn. Incorrect NC Display
    In Mach3Turn the NC is not displayed correctly: extra circles in the NC display window.
    Mach3 completes the arc to the circle.
    How to fix it?
    The text of the nc file in the application
    Thank you!
    Re: Extra Circles In Mach3turn. Incorrect NC Display
    In several lines it is required to replace G2 with G3. And check the settings for processing arcs. It's not a problem Mach. See correct file in attach. I have it displayed correctly. You speak russian? Sent me PM
    15362
    Quote Originally Posted by Actor28 View Post
    How to fix it?
    Thank you!
    Try this in the configuration page change the I/J mode
    Mactec54
  1. Mach3Turn Canned Cycles G81-G89
    By sysel in forum Mach Lathe
    Last Post: 05-27-2012, 12:15 AM
  2. Mcam: incorrect display of DXF
    By alleszerspaner in forum Mastercam
    Last Post: 11-16-2011, 08:59 PM
  3. Mastercam Lathe ----> Mach3Turn
    By skmetal7 in forum Mach Lathe
    Last Post: 11-21-2009, 12:10 PM
  4. Mach3Turn - 1st 'Beta' release of the SilverBlue Screenset for lathes
    By santiniuk in forum Screen Layouts, Post Processors & Misc
    Last Post: 03-09-2007, 04:55 AM
  5. AutoCAD 2004 to Mach3Turn
    By Edward Perera in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-31-2006, 05:13 AM
