586,065 active members*
4,349 visitors online*
IndustryArena Forum > Manufacturing Processes > Turning > Chuck not moving but the open and close light work.
    Sep 2020
    Hi, I have mori seiki cl 203, a problem with door switch where I have to one and off the machine few time.
    Now the Chuck is not moving. I don't know where the error comes from. The light shows that the chuck is close, and when I open with the pedal, the light comes off.
    Is it any parameters problems, please?
    Re: Chuck not moving but the open and close light work.
    It's probably that faulty door switch. The chuck won't turn if it thinks the door is open. Best check the wiring on the door switch and make sure it is all good.
