586,065 active members*
4,385 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Gap between tool and holder in backplot and sim
Results 1 to 7 of 7
    Sep 2020
    14
    So I made a custom tool and modified a tool holder. When I change the protrusion length, all it does is change the gap between the tool and holder. This won't work for collision checking. I am using V31 Bobcad.
    Thanks for any help!
    Sep 2020
    14
    Re: Gap between tool and holder in backplot and sim
    Version 32, sorry...
    Dec 2008
    4548
    Quote Originally Posted by GCSRT View Post
    Can you show a screenshot of the geometry you used to make your custom tool?
    Sep 2020
    14
    Hope this works!
    Mar 2012
    1570
    This videos shows the steps I've used in the past.
    https://youtu.be/h4o52I9hZU8
    If you are running V33, why not create a tool on the machining cloud and just import it?
    https://youtu.be/WC7q3wjRsq4
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    In that case I would recommend updating your tool profile, making sure to extend your tool geometry for the proper protrusion length. I would need to talk with the support team for the proper workflow.
    Al DePoalo
    Sep 2020
    14
    Thanks for the Quick Tip. Pretty sure my tool geo is correct. Here is a screen shot of what I get. The holder always says the same distance away from the tool. If I shorten the protrusion, the back end of the tool gets shorter and the holder won't move down with it. I have a demo version of 33 but ran out of time to try the machiningcloud. Is anyone using it succesfully?
