586,070 active members*
3,409 visitors online*
    Breakout board - Spindle Wiring
    Replaced breakout board with a cheap 5 axis board. Have it all working except the spindle.
    This is the board
    Lastest wiring attempt I have
    Cm (inverter) - pin 17 (breakout board)
    Fwd - gnd
    Ai - 0-10v
    And no jumper on the relay
    Ports and pins settings are
    Nov 2012
    1267
    Re: Breakout board - Spindle Wiring
    What do you have in "Ports and pins - Output signals" and "Ports and pins - Spindle setup"? Try this:
    Output signals:
    - Output #1 enabled, port 1, pin 17.
    Spindle setup:
    - "Use spindle motor output" checked
    - "PWM control" checked
    - "Disable spindle relays" unchecked
    - "Clockwise M3" output #1
    Nov 2012
    1267
    Quote Originally Posted by IhateDoug View Post
    Fwd - gnd
    I don't think you have these wired right either. I personally would NOT wire the inverter directly to P17, I would use the onboard relay instead.
    Thanks for the advice - Always the way but managed to jag it not long after posting this (have been trying on and off for near a year - 2nd Hand dodged up machine)
    Isnt much info on spindle setup for these boards so just for anyone else having the same issue, I ended up connecting
    Inverter cm - relay on break out board
    Inverter fwd - other relay pin
    And set Mach3
  1. Breakout Board Wiring
    By Pmccourt in forum DIY CNC Router Table Machines
    Last Post: 06-09-2019, 06:12 PM
  2. Need help wiring VFD to UB1 breakout board
    By hl68fx in forum Spindles / VFD
    Last Post: 03-01-2019, 12:43 PM
  3. Trying to ID this Breakout board/Spindle Wiring Diagram
    By Barefootboy4 in forum Spindles / VFD
    Last Post: 12-27-2017, 10:57 PM
  4. wiring without Breakout Board
    By tpsimer in forum DIY CNC Router Table Machines
    Last Post: 02-16-2017, 09:02 PM
  5. Breakout board wiring help!
    By frostyshoal in forum DIY CNC Router Table Machines
    Last Post: 05-08-2013, 03:05 AM
