586,061 active members*
4,342 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > Z-differences between machined surfaces of equal height in model
    Feb 2019
    I'm machining in plastic stock and a 10mm ball nose (0,39"). I have run both a "parallel" program and a "morphed spiral" program on the same model, and I get similar discrepancies between the model and the machined parts from both programs.
    Mainly: The middle area marked in the pictures is lower than the two ends.
    Any ideas on what might cause this?
    Feb 2019
    Re: Z-differences between machined surfaces of equal height in model
    More details; the parts marked U are raised and the parts marked N are lower. The zoom photos are of the part made with spiral passes.
    Attached Thumbnails Attached Thumbnails IMG_0278 (kopia 2).jpg   IMG_0281.jpg   IMG_0281 copy.jpg
    Jun 2013
    443
    Strange fault. How are you holding the pieces down when cutting them? No chance they are bouncing very slightly?
    Sometimes I have solved that kind of issue by doing the same op but in climb cut (or the opposite) afterwards.
    Sent from my SM-N970F using Tapatalk
    Jun 2015
    4154
    hi face and dial the part before begining, then run a few prefinishes and dial the part between them
    also, after removing the part from machining fixture, clamp it in another manner, with minimal holding force, and dial it again
    like this, you should find if deformation occurs during machining, or after removing it from the fixture
    it may be required to change a bit your model, in order to have a flat surface, that you may use to dial on it; is possible to entirely avoid these flat surfaces, and dial directly on a 3d complex shape, but this procedure is a bit more time consuming, and it's precision may be too high for finding the flex source; normally, i use it for surface prelevation of complex shapes, so ....
    kindly
  1. Replies: 1
    Last Post: 04-01-2017, 10:19 PM
  2. Update model (drive surfaces) X7 hoe
    By cordvision in forum Mastercam
    Last Post: 01-17-2014, 05:58 PM
  3. Replies: 33
    Last Post: 08-16-2013, 02:14 PM
  4. 3D Model missing surfaces
    By kawman in forum BobCad-Cam
    Last Post: 08-25-2012, 03:18 AM
  5. Replies: 3
    Last Post: 04-22-2012, 11:19 PM
