586,067 active members*
4,893 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > How to chain two ExtOut Boards and make them work
Results 1 to 7 of 7
    Jan 2016
    19
    Hello,
    I am building up a mill with a MK3 bord using TNG
    SW: 20.09.18
    HW: 2020.09.04
    Now I want to chain two ExtOut boards and don´t get them to work properly.
    Unfortunately I found no description in the manual or the tutorials, so I tried to connect each ExtOut board to a own ExtIn board (using SSEL2).
    But now both ExtOut boards are working in parallel.
    e.g. M64 H2 P3 Q1 L10 switches the 3rd relais on both boards.
    Connectiong the boards via the CAN screw connections lead to the same result.
    When I want to address e.g. Relais 9 I get an indication on the IO Panel on the screen but no relais to work.
    In the settings in paragraph I2C,TX, Ext I have set:
    SEL2 Pin Invert
    In Size 0
    Out Size 10
    Timer 1000
    Planet recomends 4000 but then the relays are not stable. They are switching off and on unadvertent.
    But using 4000 does not make a change for my issue.
    Does anybody have an idea what I am doing wrong?
    Best rgards,
    Marc
    Mar 2017
    1312
    Re: How to chain two ExtOut Boards and make them work
    I will investigate this and let you know.
    Mar 2017
    1312
    I'm still working on this.
    G-Code for configuring ExtOut boards to do this correctly is one of the most complex I've ever done.
    Jan 2016
    19
    Quote Originally Posted by PlanetCNC View Post
    Hello,
    any progress on that issue?
    Slowly I get nervous because my whole plannings are based on these relais boards and their function.
    Best regards,
    Marc
    Jan 2016
    19
    Hello,
    same question. 1,5 month later...
    Please be so kind to respond.
    I saw that you changed the description of the output board. You erased the promise that up to 32 relays can be connected.
    I really hope that this is only for the moment and not your idea of a final solution.
    Best regards,
    Marc
    Mar 2017
    1312
    It is possible to connect 80 relays by chaining 10 boards.
    However each board needs sequence id number. By default we ship all boards with sequence id 0. Changing this sequence ID requires I2C and CAN connection. We can do this for you until we find better solution.
    Jan 2016
    19
    Hello,
    that you for your offer. But removing and shipping would be a big effort.
    Could you provide a instruction how to programm the sequence id?
    I guess what you need is a raspberry - correct?
    I hve one of those here and it would be a help for the next user with the same problem.
    Best regards,
    Marc
