586,058 active members*
3,930 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Mill > CNC skips/transpose code during working [pctures included]
    Hello to all,
    I have a CNC 6040, operating with a Mach3 software. The problem I encounter is that during the run of the code the CNC makes one small freeze/stop and then it transposes the field of work several millimeters to one side. Then it continuous normally but transposed. I have also attached pictures to explain you.
    Any ideas??
    Thank you for your time.
    Apr 2004
    5737
    Re: CNC skips/transpose code during working [pctures included]
    This is called "lost steps". It happens when a move is commanded that a stepper is unable to execute. Identify the axis that is faulting, go into its settings under Motor Tuning, reduce the acceleration by about half, "save axis" then try the program again and see if it got better. Other causes can include mechanical issues, too high a speed commanded, not enough voltage, etc. but reducing acceleration often works.
    Andrew Werby
    Website
    Quote Originally Posted by awerby View Post
    Thank You for your response.
  1. UCCNC sometimes skips about 300 lines of code
    By eddyheide in forum UCCNC Control Software
    Last Post: 09-05-2019, 11:47 AM
  2. G-Code skips
    By rkonnen in forum Mach Software (ArtSoft software)
    Last Post: 10-19-2013, 09:03 PM
  3. Replies: 4
    Last Post: 06-01-2009, 12:08 AM
  4. A nice puzzle (g-code & vector art included)
    By PEU in forum Uncategorised CAM Discussion
    Last Post: 02-27-2007, 12:23 AM
