586,069 active members*
3,402 visitors online*
    Jul 2003
    1754
    Square turning...
    Still having fun with math and linuxcnc... created the math to add a radius to the corners - this helps with the abrupt change in direction.
    https://youtu.be/Q9zhi8Mc1fE
    Aug 2020
    20
    Re: Square turning...
    Well thx for that
    Jul 2003
    1754
    Now with arbitrary shapes...
    Nov 2017
    591
    Quote Originally Posted by samco View Post
    Pretty cool, a thought crossed my mind about this a while back. Fusion 360's new rotary tool path for use on 4th axis. Basically can be applied to any complex 3d shape. Does a spiral cut around the shape with a ball endmill. Constant turning of A axis as it controls z up and down and slowly moving back in x for stepover. Swap out the ball endmill for a turning tool like you have here and the toolpath basically works as is depending how machine is setup. Maybe slight post edit to apply cide yo the correc axis' or just mod code in notepad. Obviously need a c axis if doing on lathe. I'd really like to see it happen on a lightning fast machine that can really throw the tool back and forth quickly.
  1. X-Y axis Square: How square is square enough?
    By chmedly in forum Commercial CNC Wood Routers
    Last Post: 08-29-2018, 08:43 PM
  2. Replies: 0
    Last Post: 01-01-2018, 09:59 PM
  3. Square hole in square tube
    By bubblybill in forum MetalWork Discussion
    Last Post: 09-21-2009, 04:18 AM
  4. Question about turning to square shoulders.
    By Nelson_2008 in forum Mini Lathe
    Last Post: 08-29-2009, 01:47 AM
