586,117 active members*
3,541 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC 31i-b - DPRNT IN MEMORY CARD USING A SUB PROGRAM FROM THE MEMORY CARD
Results 1 to 3 of 3
    Hey
    I am new to fanuc, and i want to DPRNT some information to a memory card. The problem is, that my machining program is on the memory card, and i use a sub program to call my machining program to my main program.
    But i want to dprnt some information when i am running the sub program (witch is in the memory card)
    When i use a dprnt inside that sub program i have this alarm "Fanuc Alarm 1808 DEVICE DOUBLE OPENED" .
    Anyone knows if it is possible to dprnt at the same time/ inside a sub program from the memory card?
    Jul 2016
    30
    Re: FANUC 31i-b - DPRNT IN MEMORY CARD USING A SUB PROGRAM FROM THE MEMORY CARD
    It works with the DataServer. Have you tried using the DataServer?
    Aug 2023
    Quote Originally Posted by Metrologist View Post
    I was just asking about DPRNTing to a memory card! What does the DPRNT syntax look like to write to the memory card?
  1. Replies: 12
    Last Post: 01-29-2020, 01:46 PM
  2. Replies: 0
    Last Post: 08-23-2018, 04:35 PM
  3. Fanuc 16i-M memory card
    By pawlosgr in forum Fanuc
    Last Post: 03-25-2015, 02:34 AM
  4. Replies: 4
    Last Post: 04-17-2014, 10:50 PM
  5. Starting of a program from a memory card
    By t.kappo in forum Fanuc
    Last Post: 08-12-2008, 03:31 PM
