586,242 active members*
3,875 visitors online*
    Dec 2018
    5
    Spindle starts suddenly without my command!
    Happened twice in 2 weeks. My spindle starts suddenly without my command. I was sitting and playing with my phone and suddely i see that spindle starts to turn. I use chineese mach3 ethernet controller. I know there is no trust on chineese controllers but this is my 3rd controller from this brand. the other two work fine. My spindle is HERTZ 2.2kw trukish brand which is fine. VFD is again chineese brand called LiteOn EVO6000 1 to 3 phase. Controller commands vfd through PWM.
    Re: Spindle starts suddenly without my command!
    Maybe you just got lucky with the first two?
    If Mach3 is not starting the spindle, then it's the controller.
  1. Putting M3 command in G Code starts router but stops movement
    By SystemX17 in forum DIY CNC Router Table Machines
    Last Post: 03-03-2019, 04:35 PM
  2. Spindle starts when I exit Mach 4
    By cdhaerle in forum Spindles / VFD
    Last Post: 06-21-2018, 06:57 PM
  3. Replies: 3
    Last Post: 03-05-2015, 12:47 PM
  4. Mikini troubleshoot (spindle suddenly stops)
    By roberto123 in forum Mikinimech
    Last Post: 11-19-2011, 05:00 PM
  5. Spindle starts in windows explorer
    By cut2spec in forum Benchtop Machines
    Last Post: 02-27-2007, 01:49 AM
