586,119 active members*
3,439 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Code for tool radius adjust
    Oct 2020
    is there any code (Fanuc-Hurco-WinMax ISNC) which I can use directly in G-code to adjust tool radius? I need to adjust tool compensation radius for this value, not write a completely new value into tool table. I use CAM software for programming.
    In heidenhain I use code DR-<radius> right in line with TOOL CALL, for example:
    TOOL CALL "TOOL_NAME" DR-6
    ...where I can substract DR value from tool radius written in compensation table. There is similar code for Sinumerik, but I have never seen anything similar for Fanuc/Hurco.
    Thanks a lot.
    Apr 2019
    58
    Re: Code for tool radius adjust
    G41 D-tool.diam offset
    [email protected]
    +37060022992
    Aug 2009
    1573
    ...G10 Commands can do what you're looking for ( I think)
    Fanuc G10 G-Code for CNC Machine Programmable Offset Setting - Helman CNC
    Apr 2019
    58
  1. Replies: 1
    Last Post: 09-01-2019, 01:01 PM
  2. G code limitations on tool radius compensatrion - any solutions?
    By funding33 in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-30-2018, 05:42 PM
  3. Replies: 1
    Last Post: 05-15-2013, 08:52 AM
  4. adjust Tool Eye, configurate C axis
    By Nummer8 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-10-2011, 07:37 AM
  5. Nl2500 Tool setter How to adjust
    By sjlbwig in forum Mori Seiki lathes
    Last Post: 02-11-2009, 11:43 PM
