586,103 active members*
3,516 visitors online*
Results 1 to 3 of 3
    Jul 2014
    15
    Increase cavity by X and Y axis.
    Greetings of the day, Experts.
    Need a peculiar solution in Solidcam (addon with Solidworks).
    Have a cavity in the model and using it for cam program in our Hot Forging Dies. Depending of the type of forging and forging equipment, we have to either increase the cavity or decrease as compensation.
    To compensate the shrinkage allowance of the hot forged component, we would like to enlarge the cavity in X and Y axis by the desired value ranging from 0.2 to 0.6 mm in the cam program. We have tried using the Boundary-Tool Relation with selection of Internal or Centered and offset value as 0.3. But the cavity is not enlarging by 0.3/0.6mm.
    is there any other option to enlarge or decrease the cavity only in the program with the model as constant. That would be helpful.
    Please render your support, guidance and help in this regard.
    Regards.
    Aug 2009
    1573
    Re: Increase cavity by X and Y axis.
    ...Scaling ?
    How to use Scale
    Jul 2014
    15
    ...Scaling ?
    How to use Scale
    Greetings of the day, @machinehop5,
    You are referring to solidworks. but what i am looking for is a solution in solidcam to compensate the shrinkage allowance by creating a cavity by enlarging or adding the compensate to the shrinkage which could be from 0.2 to 0.6 mm depending on the grade of material, type of equipment and intricacy of the cavity.
    Regards.
  1. Taig modification to increase Y axis travel
    By Eldon_Joh in forum Taig Mills / Lathes
    Last Post: 07-28-2021, 03:14 AM
  2. Move z axis and cavity up.
    By junior1505 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-02-2020, 06:21 AM
  3. Replies: 0
    Last Post: 02-14-2018, 07:19 PM
  4. Anyone increase their z axis travel 6040?
    By jimmineycricket in forum Chinese Machines
    Last Post: 03-29-2014, 05:16 PM
  5. v22 mold cavity help
    By chromic20 in forum BobCad-Cam
    Last Post: 09-23-2008, 11:07 PM
