586,065 active members*
4,876 visitors online*
    Oct 2020
    10
    G-code Ripper
    Is anybody on cnczone familiar enough with g-code ripper to help me solve a problem?
    May 2005
    1662
    Re: G-code Ripper
    Scorch is the authority but he won't spot this thread unless you contact him. His email is under the help tab.
    Why not simply ask the question ? You might get lucky.
    Anyone who says "It only goes together one way" has no imagination.
    Oct 2020
    10
    Re: G-code Ripper
    Quote Originally Posted by cyclestart View Post
    Probe & cut wont save the file. Does anybody know why?
    Sent from my SM-N950U using Tapatalk
    May 2005
    1662
    Re: G-code Ripper
    The attached file saves as Probe & Cut using the latest g-code ripper tested in both Linux and Windows 10.
    If that file fails try a fresh download of g-code ripper.
    If the fresh download fails and no one else replies you may need to contact Scorch.
    ps: I don't know Windows well enough to know if a permissions problem is possible. I'll assume you know this stuff if you use Windows.
    Oct 2020
    10
    Re: G-code Ripper
    Does anybody no what this means. It's an error I'm getting and I would like to fix.
    Sent from my SM-G781U using Tapatalk
  1. G-code Ripper for newbie
    By Jocman in forum OpenSource Software
    Last Post: 08-25-2022, 06:14 PM
  2. G-Code Ripper - Scale, Rotate and Split G-code
    By scorch in forum OpenSource Software
    Last Post: 08-26-2020, 03:28 PM
  3. Mach3 G-Code-Ripper not working
    By madmac4u in forum OpenSource Software
    Last Post: 07-05-2020, 11:21 PM
  4. G-Code Ripper Won't run in Windows XP
    By vholman in forum OpenSource Software
    Last Post: 05-28-2020, 01:25 PM
