586,545 active members*
3,138 visitors online*
Thread: 3018 cnc
    Aug 2020
    15
    3018 cnc
    I have a 3018 that is spot on accurate when testing. I have a pen holder to see my cut out after processing. I run Candle but the same thing happens in UGS. Candle is set for inches. I try to run a 2 inch square DXF but the actual cut (in this case drawing) is about 1 mm square. Anyone that can help will keep me from throwing what to me is now a piece of junk in the dump.
    1230
    Re: 3018 cnc
    Is there a G20 or a G21 at the start of the programs you have run?It should be there to tell the machine what units are being used.
    Nov 2009
    14
    Re: 3018 cnc
    We'd be better able to help out if we knew which board and which firmware you're running, what your settings are, whether the board was shipped originally with the machine, whether it's ever been reflashed, whether the machine has ever been mechanically modified, et cetera. Otherwise, we're just guessing blindly.
    What are the first two dozen or so lines of your sample gcode?
