586,112 active members*
3,045 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > FANUC SERIES O-T parameters needed Daewoo puma 6s
    Sep 2020
    Question FANUC SERIES O-T parameters needed Daewoo puma 6s
    I have a Daewoo 6s lathe the battery died so I lost everything.
    I do have a 14 page printout of settings to use. I have input lines 001 too 8000+ manual typed in.
    I have not had any luck in getting machine to start up. But have no alarm codes to help me sort it out. There is a lot of data I can not find where to input like n900 etc
    I think it might be much more simple if someone here had a file I can upload to machine to get it to start up then edit parameter's to fine tune machine
    If anyone has a file please help
    Re: FANUC SERIES O-T parameters needed Daewoo puma 6s
    if you need parameters for puma 6s fanuc otc with 12 tools turrent i can help
    Jan 2010
    56
    Hi Wojtekthx,
    Could you help me with your Puma 6s parameters?
    I am needing to double check against my parameters, thank you!
    Having some issues measuring tools and displaying the measured offset in absolute.
  1. Need help, Daewoo PUMA 6 s missing parameters
    By RTS_Norway in forum Daewoo/Doosan
    Last Post: 11-04-2019, 03:33 AM
  2. Parameters Backup - Daewoo puma 160 lathe - Fanuc 0i TA
    By juliosantos in forum Daewoo/Doosan
    Last Post: 09-16-2019, 03:21 PM
  3. Need Daewoo Puma 230MS parameters
    By fm.ind in forum Daewoo/Doosan
    Last Post: 10-17-2012, 12:12 AM
