586,471 active members*
3,548 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > LB15 5000L-G SBP Monitor message on boot up see attached
    Jul 2007
    143
    Hi Guys,
    This machine is old and fights me every few months (it seems)! LB15 with 5000L-G control.
    I had not used the machine in a few weeks, it was fine when last I did. Anyway this morning on boot up I got this SBP Monitor message along with all the LEDs lit on the panel. It wont go any further. Tried to restart a few times, got the same result.
    Any ideas?
    Aug 2011
    419
    Re: LB15 5000L-G SBP Monitor message on boot up see attached
    Probably faulty memory unit.
    "Imagination is more important than knowledge."
    Jul 2007
    143
    Quote Originally Posted by kurmay View Post
    Hi Kurmay,
    It could be, but I also understand it the issue could also be a hardware connection issue to the control panel. BTW the message on the screen in Japanese translates to "2001 the control panel ready error 00000001"
    I'll keep poking about.
    Jul 2007
    143
    BTW can I use a panel from a my other lathe for testing? Its a 5000L looks very similar to the 5000 LG in fact the same buttons and layout, can I use these boards and panel section for testing on the LB15 ?
    Jul 2007
    143
    UPDATE:
    This issue was resolved by replacing a faulty circuit board, Okuma LC-30 Opus 5000 II CRP B Board 1911-164-1-1371 J52 XPS-442A
    From an LC-30 lathe but compatible with the LB15, slid it in and she fired right up!
  1. Okuma LB15 OSP 5000L
    By CNCAndy in forum Mastercam
    Last Post: 01-23-2022, 08:09 PM
  2. Replies: 8
    Last Post: 10-23-2019, 10:29 AM
  3. Okuma LB15 with 5000L error message
    By stude8 in forum Okuma
    Last Post: 07-25-2019, 02:48 PM
  4. Okuma lb15 won’t boot SCP monitor
    By Spacecrocs in forum Okuma
    Last Post: 04-26-2019, 02:24 PM
  5. Replies: 2
    Last Post: 06-09-2011, 04:01 PM
