587,004 active members*
2,768 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > using NPN inductive sensors for Limit
Results 1 to 7 of 7
    Aug 2020
    133
    Hello everyone,
    I'm in the process of converting my CNC Router from Estlcam to Planet CNC.
    Esltcam Required NPN Inductive sensors as limit switches. Therefore I have tose installed on the Router at the moment.
    When triggered they are creating a connection between Ground and Input.
    From my understanding the "Adapter for limit switch and input switch connection of Mk3 controller" only works with PNP sensors as it requires switching V+
    Are there any objections to connecting NPN Sensors directly to the MK3 Board?
    Mar 2017
    1327
    Re: using NPN inductive sensors for Limit
    I suppose you could do this in theory.
    But I always use optocouplers in limit switches. Those long cables all over machine can be real trouble.
    Aug 2020
    133
    Well Optocouplers on NPN does not really work from my understanding, they all require PNP as they all switch on voltage and not on ground on the input side.
    I think I will give it a try. I have shielded cables and it worked fine with the estlcam controller.
    Mar 2017
    1327
    Input and limit pins are internally pulled-up to 5V.
    Be careful not to damage them with indicative switch higher voltage.
    Anything higher that 5V on pins will damage them beyond repair.
    Aug 2020
    133
    will keep it in mind
    Aug 2020
    133
    quick update:
    I checked the sensors I have installed on my CNC and even though being NPN they seem to have some V+ parasite power on the Out Contact if they are not triggered (the once I used on the bench did not show this behavior)
    They somewhat work connected to a optocoupler but they tend to trigger spontaneously and unpredictably during rapid moves causing Estops if the estop flag is set in the configuration.
    As I have some PNP sensors on the shelf I will switch to those, it will require some relabeling but better safe than sorry.
    BTW: is there some way to see what event triggered the estop? I had some trouble pinning it down to the inductive sensors as it first looked es if it was caused by the error pin from my stepper motors. Having a message in the output windows telling which port triggered the estop would have been very helpful.
    Best Regards
    Klaus
    Mar 2017
    1327
    I'll consider this idea.
  1. Connecting PNP inductive proximity sensors to BOB
    By DanielRe in forum CNC Machine Related Electronics
    Last Post: 10-22-2014, 07:37 PM
  2. Helpful Tips For Using Inductive Proximity Sensors For Homing/Limits
    By SCzEngrgGroup in forum Benchtop Machines
    Last Post: 04-13-2013, 12:30 PM
  3. Using inductive sensors with Mach3 & C11
    By Georgie in forum CNC Machine Related Electronics
    Last Post: 05-05-2009, 11:49 PM
  4. Inductive Proximity Sensors
    By nickfox in forum CNC Machine Related Electronics
    Last Post: 09-07-2006, 03:15 AM
  5. Inductive Proximity Sensors-what are they?
    By Splint in forum CNC Machine Related Electronics
    Last Post: 08-01-2004, 11:24 PM
