586,060 active members*
3,992 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Kmotion CNC Jog buttons axis in the wrong direction
    Sep 2020
    16
    Hello,
    Has anyone run into this same issue? I have a 3 axis CNC knee mill so the table moves around the cutter (as opposed to a 3d printer or a router where the head/cutter moves around the part) and I cant get the jog buttons to not only move my table in the correct direction, but also count in the correct direction, ie: left buttons move the table to the left and count in the + direction. I have tried combinations of the following: changing the input & output gain, reversing the motor and tach wires, and changing the counts/inch in the trajectory planner screen from a positive to a negative.
    I have tried setting up a custom GIU but I am not able to change the movement direction on the jog buttons. I could just swap their positions but then the arrows will be pointing the wrong direction and with no way to change the direction of the arrow I think that would be even more confusing. I understand when the table on a knee mill is moving to the left (while looking at the part from the front), technically the cutter is going in the + direction. But holy cow is that confusing when you are trying to carefully zero on the edge of a part. Am I missing something? is there a setting for specifying the type of machine you are running? Thanks in advance for any and all replies!
    May 2006
    4045
    Re: Kmotion CNC Jog buttons axis in the wrong direction
    Hi Evan,
    You are correct that is by design. The right button should always move + and the tool to the right relative to the part regardless of machine configuration. I just imagine I'm moving the tool.
    If you still feel differently as you said you can use the screen editor to swap the button positions. You can also change the button graphics to be opposite.
    TK
    http://dynomotion.com
    Sep 2020
    16
    Hey Tom,
    Thanks for the quick reply. That is kind of what I figured, but I wanted to be sure. Would you just go download a couple arrow graphics and use those? Simply because the stock button doesn't seem to use an image file so I can't just swap them around.
    May 2006
    4045
    Hi Evan,
    If you select a bitmap it will override the default image.
    The images are in \PC VC Examples\KMotionCNC\res as Left.bmp, Right.bmp, Up.bmp and Down.bmp.
    HTH
    TK
    Sep 2020
    16
    Found them! Thank you for all of your help Tom. I really appreciate it!
  1. Y AXIS WRONG DIRECTION
    By cncbeastmaster in forum Haas Mills
    Last Post: 11-24-2014, 05:21 PM
  2. Help! x-axis is alining in the wrong direction
    By jasonaldrich in forum Cincinnati CNC
    Last Post: 07-31-2014, 04:23 AM
  3. Need Help! Y-axis wrong direction
    By ponte in forum Redsail Laser
    Last Post: 08-10-2013, 03:07 AM
  4. Z-axis only turns in ONE direction, anyone know what might be wrong?
    By effimos in forum DIY CNC Router Table Machines
    Last Post: 03-15-2012, 01:20 PM
  5. Z axis going in wrong direction
    By erkiwi in forum CNC Machine Related Electronics
    Last Post: 01-20-2010, 11:43 AM
