Re: Milli a new composite mill kit
I'm interested in how you go with ALOX / CSA mix (need a catchy brand name to hide what it is - ausidur?)
I wouldn't mind if it's more $/kg than epoxy granite. We should be looking at $/stiffness
If it is 2-3x stiffer than EG then less is needed and $/kg is misleading.
A solution that can be mixed in a standard cement mixer and poured easily has great advantage. Many epoxy granite machines have just used large blocks - lots of material not doing that much. Seems harder to get epoxy granite to work in complex forms.
Also if you don't have to wash and dry all the aggregate...!
