Apropos casting, here's a tiny mill. I wonder if those cast part are sold anywhere...
Hi Ard - They look like fabrications more then castings? Been busy getting bits finished on my workshop so it can be signed off. Today I get various bits done for the washroom & sewer... May get onto Plank2 next week... Peter
Morning All - been busy building the washroom for my workshop while waiting for Scoot the routers structural parts..... My thoughts have come back to Milli. Has anyone experience with G-Penny spindles? They claim "milling" steel but this maybe engraving? Prices seem to be good, Peter
Depends which one, they are one of the best spindles out there, I have a 2pole G-Penny and it performs very well, but there 4pole with the steel inner housing should be able to cut steel ok with the right conditions, speeds feeds and how rigid the mounting of the work piece and the machine is
The 2 pole inner housing is aluminum so would not be as rigid as the steel inner housing spindle so for the money they are a good buy, ceramic bearings as well if you want which is the best choice for any of these spindles
Mactec54
Thks Mactec - I was looking at their "metal" spindle 1.5kW ER16. Would like a square body version for Milli but round is fine... There's a couple of videos on the net showing 1.5kW spindles cutting steel quite well. But aluminium will be the main metal cut I think in this class of machine.... Peter
https://www.aliexpress.com/item/1005...36e241bdDygosn
Hi All- There is a fabricated steel truss mill (triangulated steel tube moving table) in the forum somewhere and I can't find it! I've looked at its videos a couple of times but when you want it you can't find it!! It has a 1.5kW high speed spindle and quotes the feed rates and speeds etc of it cutting steel. Anyone have a clue to where it is? Peter
Is that the machine you are talking about?
Hi Pippin - Yes that's the one thanks. I want to ask him what spindle he's using...Peter
Looked at the thread its old. he just says its an air cooled chinese spindle bought on ebay....
I love that machine, but keeping it all square whilst welding it must have been a nightmare. I wouldn't attempt it unless I had access to a BIG mill to square it all up afterwards.
Reading the history of the manufacture of my old Gorton mill ( Racine, Wisconsin ), there are stories of them putting the castings outside for several years to normalise/stabilise before final machining. It was built in 1939, so should be stable now ;-)
Brockard executed that build very very well. The triangulation is key to keeping it quite straight while welding. I think he mentions stress relief and finish machining somewhere as well. The triangular trusswork makes it really stiff vs its geometry ticks all round... Peter
When you watch it milling the only time it is happy milling the steel is with the very light cuts, If he cut a lot of steel like it was doing for the heavy cuts, the spindle would not last very long
Any of these spindles will cut Steel, ( so will a Dremel ) but won't last very long with cuts that are normal for a regular mill spindle, that is designed to cut steel
You can tell by the sound of the cut that the spindle is not suitable to be doing cuts like it is
His spindle is air cooled 2 Pole 400Hz 220v so just a regular spindle
He set his minimum speed at 6900 RPM which is an unusual speed for an air cooled spindle
Mactec54
Note that the steel he is machining 12L13 ( like cutting butter for a regular milling machine or lathe ) is around the same requirement's for machining 7075 Aluminum is to machine, the aluminum being a tougher material to machine than this steel, so is not a true test for this spindle milling mild steel like 1018 or En36 Etc. which it still could do with light cuts
Mactec54
Correct me if I'm wrong, but don't air cooled spindles normally need to run faster than that ? For example, my Perske 4.4kw is rated for 17500 to 23500 rpm. He was climb cutting the pocket with no chip evacuation, must have been re-cutting a lot of chips. I thing it was leaded free-cutting steel, but even so not a bad effort at all.
Hi All - I have sent a note to G-Penny to see if they do 4 pole metal spindles. Peter
Yes it is normally much higher for the Air cooled spindles than what he has it set at, it all depends though on the temperature as to how slow you can run these spindle
If you watch the hole plunging you will see it almost takes a dump when it did a wobble on one of the holes, that was the Bearings being pulled off there contact angle seat
Mactec54
G-penny, I did not know about them, sadly though, some of their shipping prices are kind of artificial, meaning way overpriced for the shipped weight, the cheaper ones makes sense but the better ones shipping almost as high as the spindles, add customs on top of that and you can get something from Teknomotor instead for the same price. Plus you get torque curves from Teknomotor.
Anyway I found this obscure paper on a 'budget' 2-axis milling head. Like those adjustable angle heads but on steroids. I made mockups using 23x10.2x1.7(1mm thick) bellevilles from schnorr and I was able to shorten a bt30 shaft and still get about +3500N on the toolholder while also freeing enough space at the end to put 2 bearings and squeeze a small hydraulic cylinder at the very end. The whole cartridge ended up being approx. 240mm. For the side gears I used mod1 72 teeth helical spur gears. and everything fit just nicely. So space wise it's doable.
The question is who's gonna make it...
Hi Ard and others - Milli has slowed down a bit, its crawling I suppose; its been the far horizon project. I have to finish my workshop washroom (the sewerage gets signed off today , the list is getting smaller), concurrently build YaG then use YaG to build Frankenrouter, Then I can get back to Milli. Plus my commercial and family stuff...Tecknomotor certainly have a good range of product. Will send them a note for a price on a 12000rpm model. My current Milli thoughts are to billet machine it out of aluminium. The machinist I use has a wonderful big 5axis Mazak that would do it justice... Then everything would mate and fit together perfectly... If I was building a one off at home I think CSA/UHPC is the go. Until I crack the E70 plus cast material its tough to beat aluminium unless I commit to carbon fibre.... I've tidied the workshop bench and will try to get to Plank2 next week, then at least that question is answered... Peter
Hi All - Re G-Penny 4 pole. They have responded over a couple of messages until I get the message right with my "Friend". They only have the 4 pole 24000rpm available so shall look at tecknomotor they have 12k rpm in their list... Peter
