Re: Milli a new composite mill kit
Originally Posted by
peteeng
Afternoon All - Been busy doing various jobs but got to do some refinement this afternoon. The main news is that I'm back to a "conventional" saddle bearing arrangement. History is that looking at the component deflections I noticed the lower rail is being distorted as its being "peeled" from the bottom of the gantry. If I made it rigid the stiffness jumped from 20 to 35N/um. No9-01 stiffness is 20/21/119N/um.
So I decide to compare to a conventional arrangement. The column is 94mm from the gantry with the U saddle and 120mm with the flat saddle. The flat saddle scored No9-03 19.5/25/74N/um which I think is a better compromise. Plus now the front face of the gantry can be machined in one OP. So That's probably why this is a common arrangement. Took a while to figure that one!! I did make a model where the saddle bearings where on top of each other and it did better but that is too difficult to assemble and maintain... Also I made the walls and base separate and in granite although still looking at casting. Will get a quote for granite asap. So now to add the motion and manufacturing layer to the design.
main features:
footprint 1000x700 envelope X550 Y350 Z 350mm 1.5kW high speed metal spindle , looking for iso20 spindle for slow speed (steel) Construction stainless steel and aluminium. Looking at laminating some parts for damping, saddle is ideal for this... Still want to downsize a bit.. current model mass 500kg... anything else you want to know please ask.. I also increased rails to 25mm vs 20mm Peter
Instead of Z bearings above and below gantry bearings, have the gantry bearings spread wider apart, either side of Z (instead of hidden behind)
Because gantry goes over the column walls there is room to do this
