Originally Posted by
StrawberryBoi
Supplier quality management is a dedicated position in even fairly small companies for a reason, for sure.
I completely empathize with you struggles in getting consistent results. I also agree that unless it's a robotic welder, you will never truly have the same result even with the best human welder and the same one every time.
I've dealt with similar issues with CNC processes that were multi-vendor as well. Center less grinding, of all things! We had a lamination stack for a large servo motor that needed to be +/- 0.0005" per Y14.5-2009, so a profile tolerance on the diameter and not just the average dimension.
The grinder had the proper facility and equipment, but they didn't really take seriously that we could check this tolerance with our CMM in our Q/A department. They themselves could check it, but didn't because the machine was "dead nuts", per them. Theoretically, sure, but not when you don't keep on top of wheel wear, or chucking it with sufficient precision... particularly because this was a lamination stack and the OD and ID needed to be concentric to a tight requirement as well. The same vendor would first center less grind the OD and then ID grind on a different machine.
Wr were getting only 1 in 5 to spec and they refused to acknowledge the failure. Eventually we did a visit and made them show us the entire setup process. They didn't even dial the part in on the second setup!!!
Bingo, issue found. Thst supplier caused almost $60k in losses over just a few dozen parts, not to mention our customer in the semiconductor industry was delaying a multi-million dollar machine over a tens of thousands of dollars motor.
Even in house processes require constant vigilance and process development, so yeah, going a single machine process with a single vendor makes a LOT of sense.
