587,043 active members*
3,172 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Milli a new composite mill kit
Page 78 of 109 2868767778798088
Results 1,541 to 1,560 of 2168
  1. #1541
    Jul 2018
    6452
    Re: Milli a new composite mill kit
    Hi Pippin - Heres a small router that uses a lifting gantry. It also uses a printer motherboard. Peter
    https://www.v1e.com/blogs/news/the-l...v3-has-arrived
  2. #1542
    Jul 2018
    6452
    hi all - some generic design info- peter
    NASA uses AI to make hardware that is "three times better in performance" (dezeen.com)
  3. #1543
    Jul 2018
    6452
    Evening All & you Sundry lot - I have started thinking about Milli again. So I have been doing some generative design in Fusion. I'm going to start at the Z axis and here's some snaps of the results. Since I haven't bought any tokens I can only use the previewer which is limited. The min mass and max strength result are quite similar. I'll digest this then move onto adding the gantry. But I'll review the Mori M1. The hurdy gurdy starts again! Peter
  4. #1544
    Jan 2023
    436
    hey Pete, you mentioned you figured out the saddle issue, I'm really interested in your solution...
  5. #1545
    Jul 2018
    6452
    Hi Ard- Do you remember which one? saddles have so many issues!! Peter
  6. #1546
    Jan 2023
    436
    I think it was about the newest one, the M1 clone saddle. I know, I hate saddles. A good saddle is no saddle or at least a metal monoblock and fabrications are such a gamble without heat treatment. Wish someone smarter just jumped in and figured out vsr with arduino/raspberry pi and ended this nightmare for all of us.
    Hi All - The Milli project has been parked for a while due to various things. I've been on a small trip which has given me some thinking/doodling time that has been productive. Project Milli has had two main aspects 1) material development and 2) machine configuration. The material development side tried to make a cold castable and conventionally machinable material similar to aluminium. This failed except if I use carbon fibre or (drum roll) aluminium. On the machine configuration side I keep coming back to the Mori Seiki M1 but I dislike the saddle. We'll yesterday I think I conceptually cracked the saddle issue so its time to do some more detailing to see if that works. So I'm waiting for the modulus test of some CF coupons to arrive and I can develop the new Milli in F360 and try the F360 FE module... so there's movement at the station as they say around here... Peter
  7. #1547
    Jan 2008
    1538
    You have shown a triangular gantry is the go in the past.
    DMG DMU 600 has a triangular gantry
    https://www.aeroexpo.online/prod/dmg...363-63532.html
    https://youtu.be/V7I2UvzQ_E0
  8. #1548
    Jul 2018
    6452
    Hi Pippin - Now that's a gantry!! You could convert that into a tiny home and rent it out...
    Hi Ard - Ahhh yes the M1. I took the stand that the Mill (Milli) had to be made in aluminium (or a metal laminate) and machined on a big mill to get it accurate. I like the Mori - M1 arrangement but its a typical saddle with pockets for the bolt access to the cars and its cars are nearly on top of each other. The usual issues with saddles. So I placed the cars on the sides of the ram (some call it the overhead arm) This allows access to the cars bolts, no pockets and the lands can be machined in one go from above. Assembly could be difficult but I'll work thru that in time.
    And a lifting gantry design removes the saddle so many advantages there. Plus now I'm looking at printer boards with 8 axes, the extra axis control seems to be solved so lifting gantry maybe a better path....
  9. #1549
    Jan 2023
    436
    ah side mounting, gives you more stiffness too, clever. well there are other ways to get rid of the saddle...yes I do have a thing for the moving column
  10. #1550
    Jul 2018
    6452
    Hi Pippin - Re: Mori and it uses linear motors excellent!! Peter
  11. #1551
    Jan 2023
    436
    I have a thing for linear motors too, they're badass, it's like magic. I'm exploring how expensive it would be to use them, I'm in touch with 2 chinese companies that make them. One of them is still developing higher N forcers so maybe I could get them at a bargain. Right now a C3 ballscrew w/supports and servos would go for $2000-2500 depending on the servos.
    You could technically just get the forcers and make the stators yourself but the issue remains with the drives. Every now and than hiwin forcers appear on ebay like: https://www.ebay.de/itm/254241865468 but the compatible ED1 drives almost never, and new ones are insanely expensive. I saw a used one for +$2000 once.
  12. #1552
    Jan 2023
    436
    Hi Pete, this might be of interest to you, 9 axis millturn running on Duet3 a 3d printer controller.
    https://forum.duet3d.com/topic/31653...essional-build
  13. #1553
    Jul 2018
    6452
    Hi Ard - Thanks - I think duet is going to make inroads into cnc world. Thanks for finding that. Peter
  14. #1554
    Jul 2018
    6452
    Hi All - The Milli thread has been slow but I have been trying to finalise Frankie so it can leave the workshop so I can start the next machine! But another thread has pushed me down a path and Milli has woken up again. Sika have a high modulus grout which I shall assume I can get here. I shall put in an enquiry to check I don't have to buy 35T of it. Sika-3350 E-56GPa. Plus they have a self levelling grout... My rule about a part being no more than 50kg has stymed me so I think the base has to be two pieces. I have been trying to do isogrids and other grids parametrically in Fusion with no luck. So manual it is. But The base could look like the following. In T1 image the outer parts are 50% the weight of the solid base. The small holed version does better.
    In T2 image the longitudinal holes do much better then the thru holes. makes sense as this is like a series of I beams... I did run a generative, but it didn't tell me much. So the long holes can be achieved by using plastic conduit and the base would be two parts held together by the "walls'. No I have to decide on the machine size and do some modelling... It became way too big last time I got into it... Peter
  15. #1555
    Jan 2023
    436
    technically you don't really need the bottom part of the bed. you could mount stuff to the side of the top part, the most the bottom part would do is redirect chips/coolant.
    Attached Thumbnails Attached Thumbnails f532f01b32d286c4d9eeb16b76c0132d.jpg
  16. #1556
    Jul 2018
    6452
    Hi Ard - Thats a beast - no saddle, the trunnion is on its own axis. Very nice. Separation of the axes is a good thing. I'm warming to lifting gantries...Peter
  17. #1557
    Jul 2018
    6452
    Hi All - Sika sell product through my local hardware so I can order the grout and leveller in from them. Very convenient. Now to get a quote from the hardware. Peter
  18. #1558
    Jan 2023
    436
  19. #1559
    Jul 2018
    6452
    Hi Ard - Thanks this robot config is called "Delta" There have been mills built like this but they have not scaled well and are rare. Its a great little animation and I think that will be it, I'd like to see real swarf from such a machine.. Especially with the cobot carriage. Serious machining currently needs serious structures. They also loose accuracy at the edges of their envelope. Deltas are very successful in fast pick and place applications in electronics manufacturing. Peter
    https://youtu.be/v5LCaE-7oR0
  20. #1560
    Jan 2023
    436
    the main purpose is probably welding and then machining the weld for a cleaner look, maybe something for aerospace that requires a cleanroom environment that a regular machining center would not be able to provide at this size.
    Starrag's ecospeed could be categorized as a delta I think?
    https://www.youtube.com/watch?v=qD9koFY9EKE
  1. WillMill - HSM Benchtop Composite Mill
    By Williamlii in forum CNC Wood Router Project Log
    Last Post: 05-31-2020, 07:03 AM
  2. Replies: 1
    Last Post: 07-11-2018, 04:14 AM
  3. Composite Mini Benchtop Mill / Router
    By ficklecycler in forum Benchtop Machines
    Last Post: 06-01-2018, 12:22 PM
  4. Looking for some composite routing
    By Locster13 in forum DIY CNC Router Table Machines
    Last Post: 11-02-2006, 05:20 PM
