Re: Milli a new composite mill kit
Peter, I haven't read over it in a while, but I thought the 3 plate method required changing things up regularly, not matching A to B perfectly then moving on. If you match A to B first, you can end up with a perfect dish.
So it should be regular changing between
A - B
A - C
B - C
With changes in rotation as well (e.g. don't always work in the same direction, to truely guarantee a flat plane need to rotate A vs B by 90 degrees at times)
